Strange Idle problem...
My brothers problem is when he starts the car up it jumps to 1500 rpms and holds there and nothing will get it down unless he turns the idle screw. Once done and brought down to like a resonable 800 rpms or so the car seems to develop a hiccup or rough idle condition and eventually forces you to goose it to keep it running smoothly for a couple of minutes before returning to the rough idle condition.
He has changed his plugs, wires, cap, rotor. I told his next to try to run the car and as soon as it jumps to the 1500 to shut it off and take off the throttle body, clean it good and remove the IAC and check to see where the pintels position is. Then clean is really good as well and try reinstalling it and see if that helps. If not this to try changing out the TPS sensor. (cause we have an extra off my 1990 vette and I think it would work)
Is this the direction you guys would say to go as well?
Jeff
You need proper tps voltage, proper ignition timing and a good open loop calibration and a properly functioning IAC. If there are any mods, you probably need a custom tune, or at least a heated O2 sensor to get into closed loop easier, which can provide some mixture compensation.
Proper tps voltage ensures the tps position isn't adding counts to the IAC position in throttle follower mode. This may be your problem, or you have huge air leaks or the throttle stop is screwed in way too far, which could also be raising the tps voltage out of the idle range.
Get some scan data to see what's really going on. TTS Datamaster demo is free for 20 recordings and easy to use. TunerproRT is nice but may be harder to get started with.
The maf calibration can cause problems since there is a kick up in the table #1 at the lowest flow/voltages position. This causes the flow to be over estimated and the load artificially increase and causes a very rich condition as the car is already dying.
Any mods we should know about?
I gotta try and get the laptop going
That will add around 20 counts (maybe more) to the normal IAC position, depending upon the gain factor used. This would definately cause a high idle, since according to the tps voltage this is part throttle, not idle any more.
Jeff
In this last post, you've change your story from "nothing will get it down unless he turns the idle screw", to "once the car warms up and the idle kicks down by itself to 800 rpms"
There are too many conflicting symptoms, here. I think the best thing to do is start from scratch. Clean the IAC passages in the TB, and start over with the minimum air and IAC adjustments. Then if things aren't right, come back to us. At least we will know where we're starting from.
RACE ON!!!
Basically here is where iam at right now.
Reset the air screw on the throttle body to be only a few turns in. Before it was almost all the way screwed out. This makes the plates almost completely closed. The result is at first starting it up it goes to about 1100 rpms now and then back down to 800 or so.
Once it dies down is when it starts to stumble and skip.
I haven't yet got the laptop up and running so thats the next step. Been too busy with him trying to get the brakes working.
Ill get back when i have more computer data on what the hell is going on with the car.
jeff
thanks for the help so far
We changed out the TPS and the IAC and played with them to get the minimum air correct.
We also changed the whole distributor so its brand new.
Car now runs perfectly fine now when first started up and while it is cold.
Once it warms up, the problem begins.
Stumble, rought idle, skipping feeling. No check engine light, so no codes.
I tried scanning the car, but for some reason my code scanner and computer won't connect to his 89 ECM so thats out.
What you guys think?
jeff
Also, just a thought, check all your vacume line for leaks and or cracks or decay. The smallest leak will definitely effect a stumbling idle condition.
If you don't have an AFPR, try pulling (and plugging) the vacuum line that goes to the regulator for a simple test.
Disconnecting MAF thinking that might have been it. Same problem.
Car runs perfectly smooth now when it is in open loop. As soon as she goes into closed loop and drops the idle and begins running like poop. KEEP IN MIND CAR FAILED EMISSIONS CAUSE OF NOX.
same symptoms:
rough idle at 650-700rpms
feels like a skip and stays throughout entire rpm band even as you rev it.
need more help in diagnosing this.
NOx peaks with a lean mixture (around 16:1 AFR). Rough running is also a lean symptom as the lean limit (lean misfire) is approached.
As you get really lean (18:1) HCs will begin to increase due to the unburned fuel from the lean misfire condition, but NOx should be coming down at this point. I guess your running somewhere in between the NOx peak and lean misfire limit.
Again, I would suggest raising the fuel pressure, unless you have some other means of enrichening the mixture (chip tuning).
, a bad TPS could do this....
