Coolant Problem
Old May 1, 2006 | 04:42 PM
TONYDEE64's Avatar
TONYDEE64
Originally Posted by LPDesRoche
I'll throw in my .02 here as well. If you have a waterpump that moves coolant too fast you car will not cool properly either. The coolant does not have sufficient time in the radiator to exchange the heat across the fins. I have personally had this happen to me. I was pulling my hair out, until someone noticed I had a hi flow waterpump. Swapped it out for a stock replacement and problem solved. This was on a supercharged car as well.
I fear you may be exactly on the money my friend!!! I think if I had a regalar old belt driven water pump my problems would be solved. I do have a 33gpm Mezierre that I used to run and the motor seemed like maybe it did a bit better, the guy at Mezierre said my water pump was too small and I then bought a 55 gpm pump. The larger pump will empty out the coolant system in a flash!!!
Old May 1, 2006 | 04:49 PM
rick lambert's Avatar
rick lambert
THAT combined with no thermo should answer your question.
