I would appreciate it if someone would tell me how to display error codes on an 88 with a paper clip. I have done a search but didn't come up with the exact question and I hesitate to experiment. Thanks, John
Insert the paper clip bent into a "U" shape between the A and B terminals of the ALDL connector, located above the driver's right knee, on the bottom of the carpeted panel.
If you have an Autozone nearby, check with them to see if they are still giving away a free "jumper key'. A paper clip will work but the key is handy to have and easier to use.
You jumper the ALDL with the engine off and count the flashes to get the codes as explained by the site that 86PACER posted. That is the Diagnostic Mode.
You can also use the jumper with the engine on and running to put your ECM into Field Service mode and see if the ECM is going into closed loop. From the 88 FSM which states in Section 6E, page 6E-5:
If the Diagnostic terminal is grounded with the engine running, the system will enter Field Service mode.
... In "Open Loop" the "Service Engine Soon" light flashes two and one-half times per second.
In "Closed Loop" the light flashes once per second. Also, in "Closed Loop" the light will stay OUT most of the time if the system is too lean. It will stay ON most of the time if the system is too rich.
Got mine from there. It makes it easier and its more stable when in Field Service Mode. They had a box of them an the guy said they never use them anymore.
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
Originally Posted by GRX
Make sure you ground yourself by touching a cold water pipe before doing this. Static electricity can destroy the ECM.
It has to be a cold water pipe because a warm or hot water pipe won't do.
Excellent advice if handling the ECM, as static electricity can easily damage it. In this case the procedure being done is grounding the ECM at terminal B to A (ground), so it is pretty hard to hurt the ECM with static electricity. Now if you appen to have an arc-welder or some 440Hz equiptment running close by, take the exta precaution.
I strongly suggest a visit to Auto Zone on the ECM "key" as they call it. I got a handful of these a few months ago by asking for one key......and they are free. Hellava deal!!!
The temperature of the water in the pipe isn't important, but that it be a "cold water pipe" is. A "cold water pipe" runs back through the meter and through the earth (ground) to the main, in the middle of the street, in most cases. Many hot water heaters have the hot water outlet pipe isolated from the cold water inlet, making for an indirect and a poor connection to "ground". It's that simple.
RACE ON!!!
Explain this "hot water heater" thing too. If I already have hot water, why would I want to heat it?
