Warning: To everyone lowering their vettes...
Old May 3, 2006 | 01:13 AM
goldeneye_vet's Avatar
goldeneye_vet
Thanks for the heads up CentralCoaster! I'll be doing this project while the bumpers are getting painted. Nice to know beforehand!
Old May 3, 2006 | 03:28 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Originally Posted by GRX
Are those lowering wedges made out of urethane? I have some in the garage somewhere that never got installed. What if you where make them from something more durable like delrin? Something that wouldn't compress....just a thought.
They feel like poly. I think they'd hold up better if they were rounded on top, kinda like what they ended up as after being squashed. Anything to hard is going to chew itself up on the frame or bind up the spring, or be noisy as hell.
Old May 3, 2006 | 07:08 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Originally Posted by DieL
I chopped the ends off the springs instead of all that work. Interesting discovery though
You did WHAT??? Can you explain this a bit better and maybe show some pics??
Old May 3, 2006 | 07:28 AM
87vette's Avatar
87vette
He means he cut off the ends of the spring retainer brackets that come with the lowering kit. I did the same. Cut an 1/2" off.
Old May 3, 2006 | 08:03 AM
Casethecorvetteman
I need to see pics to be sure of what you are both talking about here.
Old May 3, 2006 | 08:04 AM
bdaly84's Avatar
bdaly84
When you guys are saying you cut the spring retainers that came with the kit, are you refering to the spring upgrade kit that is extra besides the wedges and bolts??
Old May 3, 2006 | 08:29 AM
87vette's Avatar
87vette
This kit is needed for the 84-87 Vettes to be able to do the front lowering. The brackets are the aluminum brackets you see in the pic. Just cut off about 1/2" at the end where the bracket bolts onto the frame.
Old May 3, 2006 | 08:57 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
He probably means he reduced the thickness of the rubber spring pad that sits on control arm.
Old May 3, 2006 | 09:38 AM
GRX's Avatar
GRX
Old May 3, 2006 | 10:38 AM
CentralCoaster
Well, I'm still hoping for pics of a sawzalled leaf spring. So I pulled it all apart monday night, got it all back together last night, then just need to do upper balljoints and fwb's. This weekday stuff is killer, it took 15 minutes just to get all the grease off me so I can head to work.
Old May 3, 2006 | 10:42 AM
CentralCoaster
Didn't GM widen the spring in 88? These aluminum brackets are much wider than the steel ones, and don't cradle the sides of the spring at all. Hopefully the control arms keep the spring centered in there.
The narrower steel clamps always caused nasty squeaking/creaking anyways as the inner sides of them rubbed on the spring pivots.
Old May 3, 2006 | 10:50 AM
Casethecorvetteman
This is what i thought he meant too, and id really like to see this if he did. Mine has some kind of wedges under it and i havent looked at removing them, but the people at the suspension place told me they wouldnt do it if it was their car, i personally counts see an issue with it, so im interested see and hear other opinions.
Old May 3, 2006 | 12:27 PM
  #33
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Good info, it's better to get a rearched spring, also a lot more $$$
If you go for it, Vette Brakes makes an adjustable front transverse spring.
Old May 3, 2006 | 12:38 PM
  #34
js292's Avatar
js292
I think I probally need to take a look at my front spring after reading this, when I got the car the front sat so low the tires rubbed the underside of the hood when leaving my drive. After I replaced the shocks it raised it enough to keep from rubbing but the way my car sits now there is no need for the lowering kit in the front
Old May 3, 2006 | 12:49 PM
  #35
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Originally Posted by CentralCoaster
No shet. I was hoping you had a more constructive answer, I've never seen a newer spring.
So I guess yours was like 87vette's spring? If that's solid rubber, than I suppose you could just carefully trim that, remove the spacer, and not even need the wedges right?
Here is a 93 spring...
with the new wedge
Old May 3, 2006 | 03:50 PM
  #36
87vette's Avatar
87vette
Your 93 spring looks exactly like the one on my 87! I wonder if mine got swapped out before I bought it at one time or another?
Old May 3, 2006 | 03:54 PM
  #37
CentralCoaster
Anyone know when the design was changed? 88 is just a guess, based on the suspension changes.
To Warning: To everyone lowering their vettes...
Old May 3, 2006 | 04:13 PM
  #38
Vetracr's Avatar
Vetracr
I remember my 86 front spring mounts were as described in one of the previous posts, i.e, an aluminum block in a nylon saddle covered with rubber. I just lowered my 93 and the supports were solid rubber. The 90spring I replaced the 93 with also had solid rubber. Regarding the ends of the springs, I can't recall what was on my 86 but I know on my 90 I had an approximately 3/8" thick rubber pad that went between the spring and the LCA. My 93 had a 1" tall approximately 1.5" diameter cylinder of rubber bonded to the spring.
I replaced the 93 spring with a 90 R9G suspension spring that had no pad on the ends. I bonded a 1/4" piece of delrin to the bottom of the ends of the spring to ride on the LCA. I cut the stock rubber supports, installed the wedges and left out the aluminum spacers. The result was a car that sits very low, less than 26" to the top of the wheel well. Based on the original post, I might have to go back in and put the spacers back in.
Larry
Old May 4, 2006 | 06:40 AM
  #39
bdaly84's Avatar
bdaly84
What type of bond or adhesive are you guys using or have used for the wedges?
Old May 4, 2006 | 06:59 AM
  #40
87vette's Avatar
87vette
I used the 3M super weatherstrip adhesive for it. Now I'm finding out not to use it . Right after I just bolted everything up a few days ago.
