LT4 Dyno not good
Old May 11, 2006 | 09:30 AM
Achilleus07's Avatar
Achilleus07
Default LT4 Dyno not good
So dynoed the LT4 on a Dynojet and it only pulled 289 rwhp WITH K&N open air filter AND Corsa Exhaust. That comes out to like 319 hp total or so....something cant be right. It has 122k miles on it but still shouldnt be that much hp loss right? Especially since the car has been kept in great condition. Do you think it could be a simple tune up issue? Where should I start checking first? It just feels sluggish in my opinion....its like some days the car just takes off and other days its alot slower. Plus if I take off into high RPMS and let off it back-fires loud, running rich in my opinion. Can you guys give me pointers into finding out whats wrong and why im losing so much hp?
Old May 11, 2006 | 09:53 AM
vader86's Avatar
vader86
Needs a tuneup, plugs/wires/fuel filter first, then check for cat clogging.
Might want to check your fuel pressure readings as well.
Old May 11, 2006 | 09:54 AM
SLOWRIDE's Avatar
SLOWRIDE
Sounds like it needs a tuneup. Your cats may be getting clogged. When is the last time it was tuned up. Good Luck
Old May 11, 2006 | 09:56 AM
neat's Avatar
neat
Welcome to the real world man, lol.
What kind of dyno were you on? I assume it's a dynojet 240C?
The numbers are a bit low, but I doubt there is any serous horsepower left in it. You might be able to pick up ~10 RWHP from a tune up, but I wouldn't hold my breath.
Most of the LT4's I have actually witnessed on the dyno make 300 RWHP +/- 10 HP. You'll see lot's of people claiming higher numbers than that on the internet, but that's the Internet.
How does it run at the track? Maybe the dyno was reading low?
Old May 11, 2006 | 10:07 AM
tjwong's Avatar
tjwong
That isn't far off from reality. On my mustang dyno, a bone stock LT4 would run very close to what your numbers are. Post a dyno graph and lets see if there is any indication of severe knock retard. That is usually indicated by a power curve.
Old May 11, 2006 | 10:26 AM
1996man's Avatar
1996man
What was ur AF ratio? my LT4 dynoed a lot lower than i wanted with all the mods i have but i was also running waaaay rich on one cylinder so i htink that was costing me a lot of power. as others have said i would look into replacing the plugs, wires, fuel filter, and check the cats for being clogged.
Old May 11, 2006 | 11:10 AM
Achilleus07
Actually might be cat clogging....actually my right cat has been rattling and blowing out ceramic...that started after they dyno. It rattled loud for awhile and I blew it all out...or thought I did. Then it started again 2 days ago....so I blew out more. The A/F ratio was equal when it was dynoed. I couldnt say it was rich or lean...it was pretty middle road. The weird part was it got up top on the dyno sheet and then freaking jumps up and down like a lightning storm 5 hp up, 5 down, 5 up, 5 down. I will try to get a scan when I get home tonight. I ordered my EM headers and new Hi-flow cats 2 weeks ago....so whenever I get those the cat problem is fixed, wires are sitting at home, plus a fuel filter....so I will get all that done soon. then as for the dyno-tune or chip order...I really havent decided what to do yet.
Old May 13, 2006 | 01:53 PM
STEVEN13's Avatar
STEVEN13
Hi,
Sorry to hijack thread-but my 1992 (LT1) with 100,000 miles all stock except for Borla muffers dyno'd at 273hp and 305tq. This was on a Dynojet (STD). SAE was at 266hp and 297tq.
Whats the difference between STD and SAE?
Thanks,
Steven
Old May 13, 2006 | 03:26 PM
88BlackZ-51's Avatar
88BlackZ-51
I was just at the C4 meet at Bowling Green. I saw 3 stock LT-4's on the dyno. 297 rwhp/299rwhp/308rwhp. There were the average of 3 pulls. I was impressed. These cars were stock!!!!!!!!!!!!!!!
Motors are under rated!
Old May 13, 2006 | 04:26 PM
89b2k's Avatar
89b2k
Asuming this is a manual trans, 15% drivetrain loss on the dyno would give you 340 hp at the crank if you dynoed at 289 hp. Looks good to me.
Old May 13, 2006 | 11:09 PM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
My stock LT4 put down 292rwhp. Dynojet.
Corsa exhaust uses 2.5 inch pipes? If so that is part of the problem. Stock is 2 3/4
Old May 14, 2006 | 04:39 AM
DieL's Avatar
DieL
The car can be kept in great condition, but with 122k miles not everything on the motor can stay that way. Im betting theres a huge loss just from a need of tune. Not custom prom tune i mean just maintenance. it could be something very small like a sensor causing a loss in hp. Try your plugs/wires, maybe check your tps to make sure you are getting wot, o2 sensors could be clogged, cats too maybe?
good luck !
Old May 14, 2006 | 11:18 AM
1996man's Avatar
1996man
What color was the stock LT4 you saw make 309rwhp?
Old May 14, 2006 | 01:45 PM
Perfusion's Avatar
Perfusion
Definitely agree that a tuneup is needed...
Old May 15, 2006 | 09:38 AM
Achilleus07
Really, I didnt know that. Where did you find the specs for that?
Old May 15, 2006 | 09:48 AM
4REGT4's Avatar
4REGT4
Well.... he is probably right and wrong... I don't know about the LT4 exhaust - but the stock LT1 exhaust goes from 2.75" down to 2.5" in the resonator - back to 2.75" - then RIGHT before the mufflers goes all the way down to 2.25" - ... I've changed mine since those measurements, but the LT1 certainly does not have 2.75" piping all the way through (despite what others may say)... IF the LT4 has the same exhaust pattern I couldn't imagine a full 2.5" Corsa system causing ANY problem on a stock LT4...
EDIT: - also note that his rwhp rating was only 3rwhp more - even on the same day/ air conditions - the same car can pull a difference of 3rwhp on a dyno...
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
on their website.
http://www.corsaperf.com/c4.htm
CUT and PASTE:
Unrestricted straight-through muffler design increases exhaust flow by 42%
Patented RSC Technology eliminates 1500-2200 RPM interior Resonance
Mandrel-bent 2 1/2" system
Handcrafted of 100% stainless steel
Exhaust tips are made of 304L stainless and welded in place for perfect alignment
Complete cat-back system with hardware and full installation instructions
Direct bolt-on installation – No cutting, welding or modifications required
50-state emissions legal, made in the U.S.A.
All exhaust systems are wrapped in plastic and carefully packed with custom die -cut inserts and inner packs to protect each muffler and tip ends and shipped in double-wall high impact resistant corrugated shipping cartons
CORSA's Power-Pulse RSC™ C4 exhaust systems are made in the U.S.A. and backed by a limited lifetime warranty that is "guaranteed for as long as you own your C4 Corvette".
Might not seem like a big deal but every little bit matters. I've seen, with my own eyes, stock LT4s dyno in the low 290 rwhp range. You are not that far off. Do a tune up, replace the O2 sensors as other forum members have suggested.
To LT4 Dyno not good
Old May 15, 2006 | 10:06 AM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
I have the stock exhaust in my garage from my 96 GS. I'll take a look tonight. I've read the stock setup is 2 3/4 all the way. There is a lot of conflicting information on this forum and I very well could have added to the problem; if I did I apologize in advance.
In any case going from 2 3/4 to 2.5 will make a difference. I gained 12rwhp by going from 2 3/4 to 3 inch with a 383. Granted a 383 would benefit more then a 350 but every little bit helps.
You know if you put your car on another dyno the numbers will be different. time slips hold more weight then dyno numbers.
290rwhp is around 330flywheel. LT4 are rated from GM with 330HP
Old May 15, 2006 | 11:46 AM
Achilleus07
Actually I did read alot of posts that say 2.75" stock...I have the exhaust sitting at home too I can check. I think im going to switch to a B&B 3" system regardless. I should have done that from the start with an LT4.
Old May 15, 2006 | 12:09 PM
96 lt-4's Avatar
96 lt-4
a lot of good advice given here.i would go the tuneup route first.cover all the basics(plugs,wires,fuel filter,cats,sensors).all of these need to be up to snuff so you can get a true baseline.then change the exhaust if you want.that's the only way to know if it was a restriction anyway.no matter how fast i go it always needs "just one more thing".
