[Help]Car still won't start
Old May 14, 2006 | 12:23 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
To check your injectors get a white 5 gal bucket and pull the rails.Put them in the bucket and have someone turn the car over and watch the flow.
Old May 14, 2006 | 12:39 PM
n1kki6's Avatar
n1kki6
Just pulled them, when cranking their is like two that trickle but no spray so maybe their is a clog or something. Could stlil be the pump or filter but pressure is still holding at 33 psi 35 minutes later.
Old May 14, 2006 | 12:47 PM
n1kki6's Avatar
n1kki6
Ok big WTF, just drained some gas and it seems their is somethingi n my gas that might have clogged the injectors. You can see gas and then in it their is something that looks completely different and separate almost milky looking. I wondered if someone put something in my gas tank but I have a locking cap. What could this be just bad gas from the pump. It happened a the day after filling up and after filling up I probably only drove about 15 miles.
Old May 14, 2006 | 12:58 PM
n1kki6's Avatar
n1kki6
Here is a picture. Kind of blurry.
Old May 14, 2006 | 01:00 PM
RRT vette's Avatar
RRT vette
Looks like you found the problem. You will need to get all the gas out of the system and tank. This milky stuff what ever it is has clogged the fuel system. IMO
Old May 14, 2006 | 01:28 PM
rick lambert's Avatar
rick lambert
and I'd head back to the station and ask, what's up? some of the 76 stations out here were paying to have their customers injectors cleaned. Now I'm kinda wondering if you didn't get some Diesel.
Old May 14, 2006 | 01:35 PM
n1kki6's Avatar
n1kki6
I dont know what it is, someone also said maybe they routed the e85 wrong. I know I pumped 92. I have my receipt and the gas station is getting a call later today. I dont know how I am going to get the injectors spraying again though cause this crap clogged them. Any ideas or do i need new injectors.
Old May 14, 2006 | 01:43 PM
RRT vette's Avatar
RRT vette
Well they can be cleaned but I've heard it cost some where around $100. Could be less. New injectors could cost about $200 or so. I would contact the last place you bought gas and see if anyone else has had this type of problem with them, before I did anything.
Old May 14, 2006 | 01:52 PM
n1kki6's Avatar
n1kki6
Called now waiting for a call back. I am sure it wont go anywhere though.
Old May 14, 2006 | 02:11 PM
RRT vette's Avatar
RRT vette
It probably won't go anywhere unless others have reported this problem with them. It sucks, and is no better than someone putting sugar in the gas tank. Rick said he wonders if it was diesel??? Surely not but sh** happens all the time. How many miles do the injectors have on them now?
Old May 14, 2006 | 02:30 PM
n1kki6's Avatar
n1kki6
60, I changed them out when I bought the car at 65k. Up until now the car has basically been mechanically perfect. I just got everything drained and rain some good gas through a couple times and drained that as well. I will report back soon and let everyone know if it starts. Thanks for eveyones input on this you guys are awesome.
Old May 14, 2006 | 02:37 PM
n1kki6's Avatar
n1kki6
Fired right up.
Old May 14, 2006 | 03:29 PM
  #33
n1kki6's Avatar
n1kki6
Well that was short lived. Im going to try and get the gas station to pay for new injectors.
Old May 14, 2006 | 04:21 PM
  #34
RRT vette's Avatar
RRT vette
Yeah the injector will need to be cleaned by a shop or replace because they are closed in and that stuff not going anywhere unless taken out. If they gas station won't pay then if 60 mile I would just have them cleaned and if 60,000 miles I would get new ones. IMO
Old May 14, 2006 | 04:41 PM
  #35
n1kki6's Avatar
n1kki6
60,000. I am just going to get new ones. Where is the cheapest place.
Old May 14, 2006 | 06:43 PM
  #36
RRT vette's Avatar
RRT vette
Alot of guys here use Five-O-Motorsports injectors. I have also seen people flame Accel injectors. I have 24lb Accel injectors in my 86 and my stock is 22lbs. I believe yours are 24lbs stock. Look on Ebay and see what they have. I think I paid $260 shipped from Jegs for mine but you can find them cheaper than that. Good luck!
Old May 14, 2006 | 06:53 PM
  #37
rick lambert
Before you go off and get new injectors run some SeaFoam through that puppy...might just clean em right up.BTW, when I use SeaFoam, I put 1/2 can in gas, the other 1/2 I put through the brake booster line, but keep the RPMs up around 1500-1800.It will smoke like hell...but don't worry.
To [Help]Car still won't start
Old May 14, 2006 | 11:23 PM
  #38
Redeasysport
Glad you got it figured out.Definately a strange one.I have had bad gas twice in the last year but not as bad as you got.Just made the car run crappy but it still ran.Stick with Tier One suppliers from now on I use Shell but Chevron is good too.
Old May 14, 2006 | 11:24 PM
  #39
Redeasysport
After running some cleaner through mine all was well.
Old May 14, 2006 | 11:46 PM
  #40
n1kki6's Avatar
n1kki6
I will do that tomorrow along with a new fuel filter just to be safe.
