CODE 36..problem undiscovered help PLZ
Old May 13, 2006 | 06:35 PM
korvette4u's Avatar
korvette4u
Default CODE 36..problem undiscovered help PLZ
replace all 3relays, replaced ecm. MAF IS GOOD,,no voltage @ maF-burn off relay term C&E, NO POWER ..leads me to believe fuselink... NOW WHERE IS THAT FUSE LINK LOCATED..$$^%^&*&*&*&? WHICH ONE ??????
CALLING CFI-EFI , I HAVE THE DIAGONOSIC TROUBLE SHOOTER GUIDE 63E-A-55
Old May 13, 2006 | 07:16 PM
RRT vette's Avatar
RRT vette
Fuse link is behind the battery (bundle of red wires).
Old May 13, 2006 | 08:18 PM
korvette4u's Avatar
korvette4u
which one? any ideas?
Old May 13, 2006 | 09:42 PM
rick lambert's Avatar
rick lambert
There are several, get your ohm meter out and start checking them...You do have the FSMS...right???
Old May 13, 2006 | 10:05 PM
korvette4u's Avatar
korvette4u
yes,...ok gonna check fuse links.. but the burn offrelay energizes when the key is turn to start position.. i try again
Old May 14, 2006 | 12:49 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
To eleminate the MAF as a problem just unplug it the car will run without it.
Old May 14, 2006 | 11:00 AM
korvette4u's Avatar
korvette4u
i checked evry fuse link connected to the + post just behind and below the battery.. each fuse link has 12volts measured on both side of the node...
maff burn off relay does enerzes when key is in start position. this indicates that relay has power from the fuse link line orn 340..to c&e of the relay..
now what?
Old May 14, 2006 | 09:51 PM
korvette4u's Avatar
korvette4u
now what?
reset ecm...mometarily set code 34.. which is the Maff sensor.. reset ecm again.. start engine .. soon after.. new code.. CODE 36 again.. gonna run without maff F(&(()it..
checked voltage while engine running at the maff sensor,, using the center pin as ground,, two pins to the right are 5 volts each, to the left 2pins voltage varies,, this would be the sensing voltage. used by ecm to determine fuel ratio...it seems this circuit is working.. the code seems to set in open loop.. when engine cold no code until warm up
Old May 14, 2006 | 10:51 PM
RRT vette's Avatar
RRT vette
Are you sure the MAF is good? I know you have tested it in another vette. Also, have you cleaned the hot wires in the MAF?
Old May 14, 2006 | 11:08 PM
korvette4u's Avatar
korvette4u
i have run the maff 89 in the other 87.. no codes in the 87.. .. no i did not clean it..both maff are good.
cleaning , do ya think it be senitive to cleaning
Old May 14, 2006 | 11:15 PM
rick lambert
I think you should check the harness connection to the MAF.
Old May 15, 2006 | 12:19 AM
korvette4u's Avatar
korvette4u
i thinkin the same .. i do that tomorrow game nhl oiler 4- sj 3
To CODE 36..problem undiscovered help PLZ
