Convert early LT1 ('92 -'93 batch fire) ECM to late sequential
Question about the sys light regarding no communication between ecm and ccm. I have a 93 with ecm removed. can the sys be removed somehow?But, as you are aware, in your case, it is highly probable that there is a lack of communications between the ECM and CCM.
The CCM needs information from the ECM for security and to pass on the vehicle speed to other modules, like the ASR and C68 climate control.
The ASR needs the speed reading (along with with input from the lateral acceleration sensor, etc) to make a determination on how to respond to an ASR event. The ASR unit can use the Adjuster on the throttle, or individual rear wheel braking to respond.
So, since you don't have a standard ECM, the security handshake will never work. If you could disable that part only, it would not affect you anymore.
But, I don't see how your ASR is going to function properly.
And, even if you don't care about any of these, I don't know how to tell the CCM to ignore the ECM.
It is my understanding that the CCM "polls" the ECM for data. The CCM makes several attempts to retrieve that data from the ECM. If the CCM cannot get the data, it sets the "SYS" indication and sets a "communications failure" code.
If you intend to keep the CCM, the only possible way I can see around it is to "hack" the software in the CCM to tell it to ignore the ECM.
Tom Piper
However, when talking about this SD vs sequential, I'm talking in "closed loop" where the O2 sensor is in use not WOT.
Are you possibly talking open loop only?
I know you have replaced a few CCMs.
Have you ever put a '92 or '93 CCM in a '94 and had it function?
At this point, I don't see a reason to go through the hassle of changing it all.
But, I am curious if GM made a change in the ECM to CCM communications protocol.
Tom Piper
Question about the sys light regarding no communication between ecm and ccm. I have a 93 with ecm removed. can the sys be removed somehow? Sorry i think i already asked this.. but just curious if in any way the ccm can be accessed and the code removed? or something along those lines? Might there possibly be a way to 'trick' the ccm into thinking the ecm is there ??
I don't know if anyone has hacked the CCM Code. I do know if you hook up the serial lines from the 1993 ECM to the CCM and power the ECM it should resolve the SYS light.
If I could figure out a way to change the data stream from the 91 ECm to make it readable to the 1992 CCM, then I could use the digital gauges display on the LCD..
I just don't know where to start to look for that.
If there was a way to 'sniff' the ALDL port to see the comm between the CCM and ECM then I could possibly get somewhere
But, the only options in this area I had were to inform the CCM whether the ASR/ABS and/or C68 climate control options were in the car.
That way, the CCM knows if it should attempt to communicate with them or not.
The CCM is the master computer and it controls the communications on the serial link. The CCM polls the ECM/PCM for data; and, if the CCM is aware the ASR/ABS and/or C68 are in the vehicle, it passes this information on to them on the serial link.
The ECM/PCM has no direct knowledge of the ABS/ASR or C68.
I wouldn't be suprised if the code for the CCM to ECM was in ROM instead of being flash programmable.
Tom Piper
However, the throttle position information is passed directly to the ASR/ABS computer from the TPS sensor through a buffer/amplifier.
My guess is the ASR/ABS needs "real time" information on the throttle position that could possibly get delayed through the serial link communications.
Tom Piper
1) It adjusts the throttle with the ASR adjuster.
2) It controls the rear brakes, possibly individually.
3) It can control spark retarding.
It can use any one of these or any combination of them.
The only way I can figure the ASR can control spark timing/retarding, is to pass that information over the serial-link to the CCM, and the CCM would have to pass that to the ECM for the EST (Electronic Spark Timing) signal to the ignition control module.
So, this implies there are two way communications between the ECM/PCM and the ASR/ABS with the CCM passing that information back and forth -- because the ECM/PCM does not have knowledge of the ASR/ABS or C68 climate control.
The CCM is the only one to have knowledge of everything on the serial-link.
And, as DieL can testify to, the CCM always assumes the ECM/PCM is there.
Tom Piper
It also controls the "Delayed Accessory bus" that allows you to use your radio, power windows, etc for about 20 minutes after the key is turned off.
It also sets the time of the interior lights being on.
Without it, depending on how the relays are defaulted, you may have no courtesy lights or power window functioning.
Not to mention, it controls the entire digital readout on the dash.
Tom Piper
Or i'll just pretend it is
I think that delaye thing is gone already though i put an aftermarket stereo in and it hasn't worked since.
Tom Piper
Tom, if you really want a 94/95 PCM in the car, There is a way to do this. You can leave the stock ECM in place, then piggy back a 94/5 PCM to take over engine management. That way the CCM and the old ECM can talk all they want to. The late model PCM would take over all fuel management. However this would delete the VATs system entirely.
I still think it may be doable, but I would have to know for a fact the '92 CCM would communicate with the '94 PCM.
Tom Piper
So, this implies there are two way communications between the ECM/PCM and the ASR/ABS with the CCM passing that information back and forth -- because the ECM/PCM does not have knowledge of the ASR/ABS or C68 climate control....
Tom Piper
If they are all like the '96, the statement I made above is incorrect.
The ABS/ASR has a dedicated output directly to the ECM/PCM to signal it to retard the timing for an ASR event.
I'm going to try to see if the '92 has the same connections on the same pin in the harness.
Tom Piper
I didn't know the 92-93 LT1's were batch fire until I read this thread. I assumed that it was sequential. Once I started reading the posts I was interested in trying the mod to sequential but now I am convinced to stick with what I have. I am one of the ones that prefers speed density anyway. Thanks for all the good info.
On my Gen1 SBC with Minram and batch fire (using a 90-91 $8D system), I had really good results by putting ~10% bigger injectors on cylinders 1-4. I run 30 lb injectors on cylinders 5-8 and 32 lb injectors on cylinders 1-4. I then set my injector constant to 31 in the calibration. Splitting the difference like that resulted in essentially no change to the VE tables either.
If you look at the fuel trimming in the calibration for 94-96 ($EE), that's about how GM trimmed the fueling from front to rear... about ~10% richer at the front. It varies from car to car in terms how much engine load they go up to with this trimming... for example on the Impalas, they did this all the way up to 40% throttle... on Camaros/Corvettes, I think it was like only 15% throttle.
It's obviously not an exact duplication of how sequential injection works, but in terms of low/mid RPM air/fuel distribution issues that plague these style manifolds, it's a pretty good (albeit crude) approximation of how GM tuned the SEFI systems. But SEFI is mainly beneficial over batch fire at lower engine speeds so it largely accomplishes the same goal.
Of course the front cylinders will run richer at higher rpms, but I'm ok with that... it's a good trade for how much better the car runs at lower speeds. So for example on my wide band, the car seems to make more power at about 12:1 vs 12.5:1... at least by seat of the pants feel... (due to the front cylinders running richer).
