Corvette Temp. (L98)
Old May 18, 2006 | 05:24 PM
corvette_crimson's Avatar
corvette_crimson
Default Corvette Temp. (L98)
I own a Late 86 corvette I bought it a week ago but the oil temp has been running around 230-240 deg. What temp does your corvettes run at. If mine is high could any one tell me how to lower it.
Old May 18, 2006 | 05:27 PM
RRT vette's Avatar
RRT vette
That does look to be a little high. My early 86 runs at 180* and none over. I have a 180* thermostat installed. Not enough coolant, leak in coolant system, trash blocking radiator venting, low oil, stuck thermostat, air in system, and fan not working are some of the causes of overheating. If it were a LT1 I would say its not uncommon to see those numbers.
Old May 18, 2006 | 07:53 PM
tequilaboy's Avatar
tequilaboy
Without cooling system mods it is normal to see 220 - 230 degree coolant temps on L98s, especially idling in traffic.
The Main fan won't turn on until over 220, the Aux fan even higher, 230-235. I would expect the oil temp to be slightly higher than the coolant temp.
This is why many install lower temp aux fan switches and modify the ecm programming to turn the main fans on earlier. Lower temp thermostats are popular, but are also the topic of nearly endless debate.
Old May 18, 2006 | 09:53 PM
corvette_crimson
Thanks for the help guys I will purchase some cooling mods soon.
Old May 18, 2006 | 10:08 PM
RRT vette's Avatar
RRT vette
My fan cuts on at 180* and my temps never run over 180 without any chip programming. I believe the stock thermostat for a L98 is 195*, so your temps are getting high! I would replace the thermostat if I were you, then go from there.
Old May 18, 2006 | 11:12 PM
tequilaboy's Avatar
tequilaboy
The fan on temp programmed into several 86 bin files I have seen is 107.75 C or 225.95 F. (broadast code (bcc) BUA, AANM, AANL, etc. but there were lots of possible bccs in 86, and I admit I haven't checked them all).
If your fan is coming on at 180 F, it would appear that something has been modified in either the chip, or a low temp fan switch has been installed. The low temp switch could also be easily wired to control the main fan.
I did this myself years ago before I got into the ecm programming.
These cars had a factory oil cooler for a reason. With 195 degree thermostats and high fan settings, they were set up to run very hot. Good for thermal efficiency and fuel economy, not so good for performance.
Old May 18, 2006 | 11:33 PM
Rich & Lisa_84's Avatar
Rich & Lisa_84
From: I live at www.domesticlugnuts.com I sleep in PA
That is not to bad for an Oil Temp.
What is your coolant temp?
Old May 19, 2006 | 02:07 AM
raisinbran's Avatar
raisinbran
Definately not bad for oil temp, but i cant say thats its normal either.
Today i reached the highest temp ive seen at 235...while humming around in stop and go traffic with 95 deg air temp. i usually never go above 205-210. Your oil should be good til 270-290
Old May 19, 2006 | 02:31 AM
MetalVette's Avatar
MetalVette
Default Mobil one
If you are really concerned you can use Mobil 1. It can lower the temperature and has a higher heat rating. Hope this helps.
Old May 19, 2006 | 04:05 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
The oil temp at times is about 20 degrees more than engine temp.
I might pull the shroud around the radiator and see if the area between the condenser and raidator are full of leaves.
I removed a 32 gallon trash can full of leaves and crud between my radiator and condenser.
Our cars are the best road vacs around.I would just see if a plastic bag hasen't gotten caught in the front of the radiator.
I always look in my rear view mirror to see if that pesky plastic bag blowing down the street cleared my car radiator.
Old May 19, 2006 | 09:59 AM
mikey whipreck's Avatar
mikey whipreck
link
Old May 19, 2006 | 10:07 AM
RRT vette's Avatar
RRT vette
Crap, I was describing my coolant temps. Those numbers are a tad high oil temps but reasonable. And as someone stated, you can use Mobil 1 5w-30 and it might lower the temps. Low oil can raise the temps too.
Old May 19, 2006 | 10:11 AM
geezel's Avatar
geezel
The oil temp on my 86L runs 210-220.
Old May 19, 2006 | 10:34 AM
torkman15's Avatar
torkman15
I have a late 86 Vette also and the oil temps have never gone over 180 even idling and stopped for long periods of time. We havent really had any warm weather yet for a good comparison either. Seems like since the oil cooler really depends on coolant temp the oil temps will be a bit higher than the coolant temps.
Cleaning the area between the rad and a/c condenser once in a while is a must.
Good luck, Tom
Old May 19, 2006 | 11:24 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Good luck, Tom
Then your car is a freak they are not designed to run that cool.
To Corvette Temp. (L98)
