4 + 3 Problems
Old May 19, 2006 | 09:57 PM
NHRA21's Avatar
NHRA21
2nd Gear
Default 4 + 3 Problems
I am a little new to 4+3 transmissions and could use some help. On the drivers side of the overdrive unit there is a electrical sending unit. Mine seems to be loose. I am guessing that there is a clip or bracket that is supposed to hold it in place, but it seems to be missing. I can't find a listing in the GM parts list for the retainer either. I was hoping someone might be able to send me a picture of this sending unit along with whatever is supposed to hold it in place. A source for this part would also be helpful.
Thanks!
Old May 21, 2006 | 01:36 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
This part just clips into the overdrive housing. It's just a spade terminal where the 12V signal goes to the solenoid inside, and has an oring.
Mine was leaking, so I cleaned it well and used "The Right Stuff" to seal it to the case.
Ac Delco p/n 24205373 and p/n 10054241. It's a pretty common connector used on the automatic transmissions too.
Old May 21, 2006 | 09:07 AM
NHRA21's Avatar
NHRA21
2nd Gear
So its just held in by the pressure of the o-ring then? Interesting. Thank you for putting an end to this mystery!
While I am on the subject tho... Where would you recommend to get a rebuild kit from if it is needed?
To 4 + 3 Problems
