TB Bypass questions
Old May 20, 2006 | 03:38 PM
split-end's Avatar
split-end
Default TB Bypass questions
What size hose goes to the inlet and outlet connecton point on the TB? From articles I've read it seems that one side is 3/8" and the other side is 5/8". Can I bypass the TB by running one hose from the inlet connection to the outlet connection? If so, what size hose do I need?
Old May 20, 2006 | 03:46 PM
bogus's Avatar
bogus
do you have a napa? If so, they sell these plastic connector thingys that will allow two different hose sizes to mate up.
BTW, it should be a 1/2 to 5/8.
Old May 20, 2006 | 04:46 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
A length of 5/8'' hose will get you from the metal tube and into the intake with no splices. Here is how i routed mine. http://forums.corvetteforum.com/show....php?t=1396218
Old May 21, 2006 | 02:39 AM
Bubba91's Avatar
Bubba91
I had to read his (split-end) public profile to find out, but he has a 96. The Lt1 TB is different than our L98.
On the Lt1 they are two different sizes (3/8 & 5/8).
Your post/pics helped me w/ mine, thanks!
Old May 21, 2006 | 08:10 AM
AGENT 86's Avatar
AGENT 86
I read his profile before i posted that and it said 89. I think he changed his profile after his PM to me.
Glad i could help you
Old May 21, 2006 | 08:43 AM
vstol's Avatar
vstol
On an LT4 which is the inlet and outlet htr nipple. Which one do we connect the line that went to the throttle body on? Top or bottom.
Old May 21, 2006 | 12:31 PM
Perfusion's Avatar
Perfusion
In the first picture, you can see the connector on the left (driver's) side of the TB where the hose once was:
In the next picture, you can see the hose going from the "T" connector atop the radiator housing to the right side of the plenum (it's the only "curvy" hose in the pic).
The end of that hose which is now connected to the plenum USED to be connected to the left side of the TB (i.e., in picture 1). All I did was remove the hose from the left side of the TB, completely remove the hose from the OTHER side of the TB, swing the left-side hose underneath, and connect it to (the plenum) where the old one once was.
The TB is now bypassed. Make sense? If not, let me know and I'll try a better explanation...
Old May 21, 2006 | 03:31 PM
vstol's Avatar
vstol
Ok let me try again and look at it. Since I have it in a 64 GS and I am not going to use the heater for right now and will have a remote filler/expansion tank so its a little more complicated. Trying to fiqure out how I need to do this. Corvette kid layed it out pretty well, I just need to know which htr nipple is the outlet and inlet so I do not mess up the flow and can connect the remote filler hose to it. The middle nipple on the passenger side right below the PCV is ??? Vacuum
Old May 21, 2006 | 03:49 PM
Raidmagic's Avatar
Raidmagic
You have a what??
Old May 21, 2006 | 08:05 PM
vstol's Avatar
vstol
I built a 64 Corvette Grand Sport from Mid America and it has a LT4 in it. I am wiring it up now.
Old May 21, 2006 | 08:58 PM
Perfusion's Avatar
Perfusion
I built a 64 Corveete Grand Sport from Mid America and it has a LT4 in it. I am wiring it up now.
Pics?
To TB Bypass questions
