L98 misfiring
Old Aug 25, 2001 | 11:57 AM
J. Fenska's Avatar
J. Fenska
3rd Gear
Default L98 misfiring
I have a '90 L98 with 150,000 miles. I've changed almost everything including plugs, wires, cap, rotor, etc. over the last year or so. I also have converted my HEI over to MSD 6A with Blaster coil, have most of the bolt on mods including a chip, air foil, fuel pressure reg, etc. I have recently developed a misfire at RPM's above 3,000 along with what seems to be a loss of several cylinders for brief moments. I've never changed the injectors, but did replace the ECM with a rebuilt about 75,000 ago. I'm suspecting that to be the problem, but don't want to start changing parts without some of your great insights into what else it might be. Any thoughts would be appreciated. Thanks, Jon.
P.S. The cat is new also....I'm not getting any codes either.
Old Aug 25, 2001 | 05:10 PM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
Default Re: L98 misfiring (J. Fenska)
Replace your fuel filter if you haven't already. Check the fuel pressure under load. Put it on a scanner and check the sensor values. This might be an intermittent failure of electrical connection. Could be MAP or TPS too.
Old Aug 26, 2001 | 01:56 PM
J. Fenska's Avatar
J. Fenska
3rd Gear
Default Re: L98 misfiring (AquaMetallic94LT1)
Thanks Aqua, I have a new filter, fuel pressure is 45 at idle, but haven't tried driving it yet with the gauge taped to my windshield, but have thought about it. Haven't tried scanning the sensors yet, either. But, your post got me to thinking about all the whinning noise my fuel pump makes when I get even a little low on gas. Maybe my pump's bad and that would show up on fuel pressure under load test you're suggesting. Thanks!
Old Aug 28, 2001 | 03:37 PM
DaddyO's Avatar
DaddyO
I had the same symtoms. Changing the MAF sensor & relays worked for me - she runs like new.
Old Aug 21, 2010 | 08:32 PM
giomeister's Avatar
giomeister
1st Gear
Default Still driving the Vette
Do you still own the banana yellow vette? the "corvette yellow"
This is Gio from the old painting crew.
email me....
To L98 misfiring
