89 Convertable air / heater control unit electrical issues
Old May 24, 2006 | 09:15 PM
baddoght's Avatar
baddoght
4th Gear
Default 89 Convertable air / heater control unit electrical issues
Hey gang....
I am new to the site, but am very glad I found it. I need some guidance regarding my vette....
1.) My heater / air condition control unit only works part time. Usually the tempature is dim to the right side of the numeric display. If I push any button, it begins to flash. Last time I drove my it, the control unit didn't even work. I later re-started the car and it was back to its usual self. My question is, is the unit bad or do I have a wiring problem? I have found heater / air condition control units on line and from GM, but they are only for coupes. If replacing the unit is the correct action, will the coupe heater / air condition control unit work for me?
2.) They other issue I have is that occasionaly, the car runs very rough after starting. It does not matter if it is cold or hot. Usually the check engine light comes on. If I give it any more the 1/8 throttle, the car dies. It usually runs rough for about 1 - 3 minutes, then the rpms shoot up to normal and I am good to go. Any ideas?
Thanks in advance for help.
Baddoght
Ken
Old May 29, 2006 | 12:01 PM
corvette1989bham's Avatar
corvette1989bham
the ac problem is your control head, the coupe unit will work.
the rough running problem...you need to find out the codes that is setting your check engine light...then post back
