ECU EXPERTS: Keeping memory in the ECU when using a master switch?
In order to avoid the situation above I would need to keep a constant ground to the circuit in the ECU that retains memory. IIRC there are four or five grounds to the ECU. Does anyone know exactly which ground I should ground direct to avoid loosing the ECU memory?
thanks,
If that is not satisfactory, wouldn't one of those devices that plugs
a 9VDC battery into the cigarette lighter hold the ECU memory while
the primary battery is disconnected? You could make your own with
a DC adapter from Radio Shack modified to be hooked up to a gel cell.
The kill switch I have is a key type. No provision to retain battery memory.
If the car will be anywhere there is some source of light, then use
a small solar panel to keep it charged. This kind of approach is
used to maintain batteries in roadside devices. Those gell cells
are in the emergency hallway lighting units and they last for quite
awhile there.
gauge fusible link across the terminals of the key switch.
You'll need to puzzle out the details but basically, the circuit
would still be hot with the key off. However, the current would
be routed through the fusible link. This would be sized to have
sufficient capacity for the demands of the ECU and courtesy
lights - if someone tried to start the car, the fusible link would
go phhhtttt.
Or do the same thing with a MiniFuse.
** --- DISCLAIMER ------------------------- **
Folks, the information above is provided with the aim of
suggesting a very general overview for consideration, it is
not intended as a detailed or complete solution. If you follow
this approach, overlook some important consideration and
experience an electrical malfunction, then all responsibility
rests with you.
thanks for the help,
a moment. The answer may be redundant after you take a look
below.
I have a rigid panel made by ICP Global that I've used for a number of
years. Didn't see it in a quick search but did come across one of their
flexible designs, along with some accessories that may be of interest.
A sampler of something that might be of interest (I've no experience
with this particular vendor.)
The newer units have regulators these days, built-in or as an optional
module. These things don't require strictly sun light, mine generates
juice in the presence of incandescent & other sources.
Also, the subject has come up before. Here is a thread from the
past with some ideas for you - Lighter Socket - Battery Tender???
Didn't know Radio Shack carried these. Than again I've never gone looking. Would they have the small solar panels as well? I suppose I would want to put this on the dash?
Thanks for the link as well. I'm not worried about the battery going dead, I just don't want to lose the ECU memory.
thanks again,
the CDN RS stores morphed into when someone had a snit and decided
to split.) Can't find what I've walked in and bought before - a fused
cigarette adapter with a length of cord attached. But here are a
couple of close proximates
270-1509 12VDC 7.5A Power Plug
270-1521 Vehicle Power Adapter Plug with Banana Jack
I'm suggesting a gel cell because I don't think a conventional 9 VDC
radio battery is going to last very long. You could pull fuses, but
this is a hit on the convenience factor.
My vote is to get a sense of how much current draw you anticipate,
select a battery with sufficient Ah capacity and then maintain the
battery with a suitably sized solar panel. A 5A battery theoretically
provides you 5 hours of current when connected to 1A draw.
Here's a link with some sample gel cells, scroll down to the 12 VDC
units.
This link has some useful information about battery charge and
discharge considerations. You'll need to scroll for it.
