Temp set button on AC
Old Jun 2, 2006 | 12:50 PM
mffi115's Avatar
mffi115
Default Temp set button on AC
The left side, temp lowering, side of the Temp Set button on my 94 is not working. I can increase the temp but not lower it. When it does this I can't control the Off, Auto, and recirculate buttons, either. However, sometimes after the car's been shut down, it will work long enough for me to lower the temp. I called the local dealer's part shop. They said the whole AC/Heat control unit needs to be replaced, not just the button, for over $200.00 for the unit. I just read the post about cleaning the contacts. If that doesn't work, what are my options besides riding around with my heater on in NM and AZ over the summer.
I have the temp set at 68 and don't plan on touching it for now. That's the cheapest and laziest option, but I like my gizmos to work.
Old Jun 2, 2006 | 01:21 PM
pr1mu5's Avatar
pr1mu5
Default well..
If you read my other post, and are willing, try smashing the unit with your hand... try a light slap on the side first, and work your way up to about a 50% power punch. It's the only way I can get mine to turn on/off. But once you get it set the right way, leave it
Old Jun 2, 2006 | 02:54 PM
JCAIRE2's Avatar
JCAIRE2
Try cleaning the contacts first. IF that doesn't work, replace the control unit. They can be found online for about $175 and you can install it yourself, not hard.
Old Jun 2, 2006 | 02:58 PM
RRT vette's Avatar
RRT vette
I found one on Ebay used for $40 shipped. Looks/works like new.
Old Jun 11, 2006 | 10:03 PM
mffi115's Avatar
mffi115
Default Thanks
I've been away from the internet awhile; so I'm just getting around to thanking you. I haven't had to do a 50% power punch yet, but getting there. I'll try the cleaning first.
Old Jun 11, 2006 | 10:18 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
It could be dirty contacts. Try this
https://www.corvetteforum.com/techti...D=92&TopicID=2
Old Jun 12, 2006 | 07:04 AM
pcolt94's Avatar
pcolt94
My first recommendation would be to clean the connections on the rear of the controller as the others suggested. I found this problem before I ever got on the Forum. That fixed mine and I got lucky.
The other problem with it is bad internal solder connections. I have read some extensive articals on this. It will take a elevated skill level of soldering and electronics repair (as indicated bt artical). I myself have not been into this all though well qualified. From what I remember, the connections between the main board and the front panel is where the problems are. If you go there, best of luck.
To Temp set button on AC
