Why the rear?
Old Jun 6, 2006 | 12:23 PM
Rapid Fred's Avatar
Rapid Fred
Default Why the rear?
I have my '93 at my trusted mechanic's for a tech inspection before doing a track day next weekend at Pocono. Car has 95K and has been well-maintained. I'm the second owner and have put 10K on it since I bought it last year.
Anyway, he only found two issues from the punch-list:
1. Rear shocks (FX3) blown (they are originals). Fronts are fine!
2. Rear brake pads low. Only 30K on them -- originals lasted 65K per prior owner records. Fronts were done 20K ago and are fine.
I always thought front brakes and shocks took more abuse than rears, and I never heard of rear pads going that quickly. Is it possible something else might be going on I should mention to my mechanic?
Old Jun 6, 2006 | 05:23 PM
5pinball's Avatar
5pinball
check your handbrake lite could be off but they brakes could be hanging up a little easy to have checked
Old Jun 6, 2006 | 06:36 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Also the calipers could be dragging, hoses bad internally can also cause drag or possibly they just put POS pads on.
Old Jun 6, 2006 | 06:55 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Could be normal wear.
Old Jun 6, 2006 | 07:12 PM
Bigredwing's Avatar
Bigredwing
I'm no expert but I think I read in a thread recently that the rear brakes do most of the work with ASR. Could be that competitive driving with the ASR on is eating up the brakes. Shocks could be old age and driving style too. If somebody can back me up on the ASR thing I'd appreciate it, if wrong tell me too.
Old Jun 6, 2006 | 08:07 PM
SSLT1KID's Avatar
SSLT1KID
maybe its just that the fronts have been replaced mre recently than the rears?
Old Jun 6, 2006 | 09:04 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
If everything is working equally well, brakes should wear about the same. On shocks, it's not that unusual to see the rears go first.
Old Jun 8, 2006 | 11:23 AM
Rapid Fred's Avatar
Rapid Fred
Default End of Story
Thanks, all
Majority of comments suggest that 30K not too bad for the rear pads on these -- smaller pads, possible ASR impact, more local driving, etc.
Mechanic checked out handbrake and Kid's add'l thoughts and no problems found.
Perhaps the prior owner just forgot to document the first rear pad change.
Anyway, off to Pocono next Saturday!
To Why the rear?
