EGR Temp Sensor
Old Jun 12, 2006 | 11:31 PM
rockinc4's Avatar
rockinc4
Default EGR Temp Sensor
I have an 87 vette with a L98. I just finished the motor and am trying to finish up some loose ends. I need to know in detail where the temp sensor for the egr tube plugs in. I cant find the connector and its driving me nuts! Thanks
Old Jun 12, 2006 | 11:56 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
behind distributor
loflyin's Avatar
loflyin
On my 86, the sensor screws into the top of the tube on the distributor end. Black wire comes out of harness at rear of head and attaches with female connector. Insulation may be covering this up. Hope this helps.
Old Jun 13, 2006 | 09:29 AM
Sam Lam's Avatar
Sam Lam
The EGR temp sensor on my 89 plugs into a connector that is laying on the valve cover directly above #6 cylinder. This is forward of the distributor. It exits the wiring harness at this point. Hope this is helpful.
Old Jun 14, 2006 | 12:23 AM
ozvette87's Avatar
ozvette87
same place as guys above on my 87.... but the wire was streching (at best) to get to the loom plug, gm doesnt have much wire to spare by the looks of it!
Old Jun 14, 2006 | 12:58 AM
rockinc4's Avatar
rockinc4
thanks for the help guys I'll check it out asap
To EGR Temp Sensor
