code--33
Old Jun 13, 2006 | 03:23 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Default code--33
I had what I thought was a problem with the vacuum/egr system until I found my code scanner. The car starts/idles/runs great until about 25-30 minutes of driving, then all of a sudden its like somebody throws a switch--- rough running, exhaust smells, idle goes from 5k to 7k up & down. If I shut the car off for about 20 minutes it goes through the same cycle-- starts/idles fine etc. I plugged in the scanner, & got a code 33---MAF sensor or MAP sensor. Which one would be the better bet to be the problem. Of course the MAP sensor is underneath the plenum, so thats going to be a PITA to replace
Old Jun 13, 2006 | 03:28 PM
vader86's Avatar
vader86
No, not a MAP on 87. Your car is probably being thrown into 'limp home' mode.
Its MAF and/or relays. Inspect the MAF wiring from the sensor to the relays, there are 2 of them behind the battery on the firewall. If the wiring checks, replace both relays, together they shouldnt be more than $25.
See if the code comes back, if it does then its the MAF itself.
Old Jun 13, 2006 | 03:59 PM
Rich Silvestris's Avatar
Rich Silvestris
St. Jude Donor '05
Kenv, I am writing to you from another corner of Code 33 hell. It's spelled MAF alright. I've replaced the relays and had it scanned and replaced the coolant temp sensor and the O2 sensor and replaced the MAF sensor and the IAC and it goes away for a while after each repair and then ......
"You can check out anytime you want, but you can ne-ver leave!"
Right now I'm riding around with the MAF unplugged. At least it runs.
Old Jun 13, 2006 | 06:55 PM
kenv's Avatar
kenv
St. Jude Donor '10
Well, while looking at the plenum, I found a sensor, underneath at the rear right by the vacuum ports. There is no connector going to this thing, & I can`t find any loose wires or connectors. Right now I cannot find my fsm (naturaly ) anyone know what it is, & could this be causing the trouble. ( let`s see, so far I gotta get two relays & another plenum gasket set. Don`tcha just love having a "hobby" )
Old Jun 13, 2006 | 07:09 PM
rick lambert's Avatar
rick lambert
I'll look when I get home...later this evening..don't forget to check the FP relays also.
Rich, I thought your problem was fixed when you installed a new MAF?
If not, it seems like after everything you've done it must be a bad wire or connection.
Old Jun 14, 2006 | 12:12 AM
ozvette87's Avatar
ozvette87
The sensor that your talking about is (i may be wrong, just going off description) the air temp sensor. this should have a connection too it, thats only if a second air temp sensor has not installed near the air filter somewhere.
Old Jun 14, 2006 | 12:16 AM
ozvette87's Avatar
ozvette87
not sure if it affects the code
try this link i got from another member
http://members.shaw.ca/corvette86/
Old Jun 14, 2006 | 07:13 AM
kenv's Avatar
kenv
St. Jude Donor '10
Thanks for the replies folks. I`ll try the relays first. The wireing seems ok.
Old Jun 14, 2006 | 07:20 AM
runner140*'s Avatar
runner140*
"Hotel California" by the Eagles (Don Henley and Glenn Frey)
Old Jun 15, 2006 | 07:33 PM
kenv's Avatar
kenv
St. Jude Donor '10
Update-- I replaced the MAF relays ( AC Delco- made in China- $20.00ea ), that did not cure the problem. Went to AutoZone for a new ( reman) MAF sensor. The wanted $221 + $80.00 core charge. The counter guy answered the phone with " Autozone, cheapest prices guaranteed). I said, " I`ll call you right back ". I called around, & the cheapest place that I could order one was Pep Boys, with a 3-5 day delivery . I went to the `Zone with the Pep Boys printout, & said " here ya go ". They weren`t happy, but I got it for $165+tax. Now I hope it cures the problem. Oh yeah; the highest price was from my local chevy dealer--- $450 reman---$680 new
Old Jun 15, 2006 | 07:36 PM
ozvette87's Avatar
ozvette87
Let us know if it fixes the problem
Old Jun 15, 2006 | 08:30 PM
rick lambert
Yeah, please let us know!! Hope you checked the wires to the FP relay, and replaced that relay also before buying a new MAF...paragraph two on both 33 and 34 in the FSMs or Helms.
Old Jun 15, 2006 | 08:35 PM
ozvette87's Avatar
ozvette87
How did you go with that sensor that was not plugged in? does your car have a sensor coming out of the airbox somewhere?
Old Jun 15, 2006 | 09:25 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I hope you went through the flow chart before you threw money at it.
As for the sensor under plenum, yes it is the MAT sensor and it should have about a 6 inch lead with connectors, that plugs in between the sensor and the main wire harness behind distributor.
Old Jun 15, 2006 | 10:35 PM
kenv's Avatar
kenv
St. Jude Donor '10
Well ;all the wires looked ok. I`ll let you know if it fixes the problem. FP relay? :o oops!, I missed that one. I hope this works, because if my wife were to find out I spent $165 for a MAF, when it could have been fixed with a $20.00 relay, my *** would be in the dog house, & the dog would be in my house, so if it turns out to be the relay- you bet your butt that I`m going to swear it was the MAF
To code--33
