The first half of your link deals with boring the TBs. The third 1/4 deals with manifold porting, and the last 1/4 deals with alternative manifolds. Porting your own (or a spare purchased just for the project) is the most economical way to go. I have some misgivings with the most popular of the replacement Crossfire manifolds, the X-Ram. However, to be truthful, I have no personal experience with one. Boring the TBs maybe a waste of time for most people. I have one of the better flowing ported stock manifolds around, and when I installed 2" TBs, the 1/4 mile time didn't change one bit. They jumped by a mile when I installed the ported manifold, with no other changes, however.
DRAKEFAMILY2's link is a good one, too. But in neither post has anywhere near the metal been removed as has been from mine.
For once you got it right. You nit picking, "valve vs drive" train, is the kind of thing YOU interrupt a thread to criticize me for (except *I* don't jump on obvious slips of the tongue or typos) even when you know nothing of the subject. YES! You ARE the pot calling the kettle, black.
RACE ON!!!
But you are missing the point. It's not the nit-picks... it's the WAY you nit-pick. I don't criticize the correction, I criticize the attitude, and the way you revel in those errors.
It's all about delivery. Read my correction - it's polite, it's nice... not accusitory or insulting.
Well actually, being that it is a stock 84 motor, there are quite a few frictional losses in the valve train (no roller cam, standard rockers, etc...but I know you already know this by your later post.) David Vizzard's Book goes into a lot greater detail on this. Personally, I belive all his books (and Lingerfelter's, Smokey Yunick's, and a few others) should be required reading for someone new to modifying engines
Hey! that Smokey Yunick nows his stuff. Building his own dual overhead cams on a small block chevy, way back when. Yep, read how to hotrod small block chevys. It's like a bible to me. I have read it several times, and I need to get out to the shed, grab it, and read it again. That guy believes in "RAM AIR" heavily. That is what keeps coming to mind when working on the vette. Read it corvette gang!!! Now go get some H.P. outta that CFI. Thank You, You have been a wonderful audience...
7.4L TB on Holley TBI manifold(Projection), Summit AC with K & N, Aeromotive FP reg, Comp Cams 224/230 @.05 114 LSA, Innovative input of tps/rpm/map data.
I have to agree. My personal belief is that driveline losses are closer to 12%...maybe even slightly less...with a manual transmission car.
Larry
code5coupe
It's all relative.
I used 15% for manual and 20% for auto, cause they are real easy to do estimates with, and that's all it is.
As far as I am concerned, the driveline will only take so much power to operate. For example, if it takes 20 hp to move the driveline, well, on a 200hp engine, that's 10%, but on a 400hp engine, that's only 5%.
Essentially, its a sliding scale... I cannot beleive that a 1000hp engine is going to be robbed of 15%?
Actually, the power consumed by the engine will go up as horsepower increases, but not proportionally(why do I think I mis-spelled that). This is caused by some of the very things that increase Horsepower, bigger cam lobes and the stiffer springs necessary to run them, higher compression pistons, higher volume oil pump's, etc.....
So what are the before and after times in the 1/4?
I have all that "before" stuff, except for the "xram, 454 injectors, edel rpm aluminum 64 cc heads, crame 2040 cam 210/216 @.05, crane roller rockers, ceramic hedman 1 5/8 headers, hooker aero chambers, 7747. Innovative WB". Otherwise our cars are (were) identical.
He made a mistake and he's still acting like a know-it-all. Your X=fire is about as far from stock as you can get. Seems like most newbies have bought an '84 this last year. Brag all you want, but it was still the crappiest C4 ever made!
Say its the crappiest C4 ever made... but when i had the X-ram, larger injectors, cam, roller rockers, cam, headers, dual exhaust, and all that jazz I ate L98's and LTx's for lunch... with a craprife lol
