I have been pursueing that same things lately. Under my corvette photos you can find my dyno results on my 84 with my mods. I am in the process now of making a few more changes. My goal has been 300rwhp. Is it possible? I think so
thanks but thats actually 207.7 at the wheels. Using about a 22% loss over the valve train my engine should be making around 260. A stock 84 at the wheels is closer to 140 or so,engine rated at 205. So I figure I picked up only about 50-60 hp with the mods (listed in profile). I think the only way to get up to the 300 mark is you will need a cam, gears. Thats what I'm working on now. Trying to figure out which one to use.
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Originally Posted by Zero Limits
I have read that it is posible to get a CFI engine above 300 ponies; while keeping it stock.... Is it true???
Uh, no.........
You're going to have to change something (probably a LOT of somethings) to get power like that out of the old girl...and then it wouldn't be stock.
300hp can be done, with a judicious choice of parts and the wise use of the checkbook.
Good luck!
Knowing what I know now. The first thing I would consider is either porting your intake yourself to save money or you could go the route of the x-ram. I did the second of the two. EITHER ONE will allow more flow.Then think about a set of headers,gears? These mods alone should give you some pretty good results. You could also cut out in your radiator shroud to allow more air to get into your duct work in the hood. Its a free mod except for the couple of bucks spent on the weatherstripping.
Wisest use of available funds, in my opinion, would be nitrous. A mild setup (100shot?) will get you close to your goal.
Otherwise, you are looking at cam, heads, intake, and headers at the very least.
Horsepower (real horsepower, not advertised horsepower) is not cheap...my own formula is that you'll spend about $50 for each horsepower you gain....and it adds up quickly.
Valve train? That had better not take any power! I think you meant Drive Train?
As for the Xfire, Alcee1 has proven it can be done. Bored TBs, bored intake manifold, Edelbrock heads, highflow cat and a few other tricks.
Well actually, being that it is a stock 84 motor, there are quite a few frictional losses in the valve train (no roller cam, standard rockers, etc...but I know you already know this by your later post.) David Vizzard's Book goes into a lot greater detail on this. Personally, I belive all his books (and Lingerfelter's, Smokey Yunick's, and a few others) should be required reading for someone new to modifying engines
Yes, but good to elaborate on for those who don't already know.
uh, 290? I think that would be the torque rating, the HP is 205. Are you quizing me here?
You caught me.
Originally Posted by bogus
The pot calling the kettle black.
For once you got it right. You nit picking, "valve vs drive" train, is the kind of thing YOU interrupt a thread to criticize me for (except *I* don't jump on obvious slips of the tongue or typos) even when you know nothing of the subject. YES! You ARE the pot calling the kettle, black.
