Oxygen sensor question.
An open sensor circuit or cold sensor causes "Open Loop" operation.
-FSM page 6E3-A-24
Based upon what you have posted so far, I'd guess that you have an intermittant open on circuit 413, the tan wire from the ECM for O2 ground. Or possibly a faulty ECM.
Code 13 FSM chart results for step 3.
-> Ign "on" Engine "off"
-> Voltage check of circuit 412 (purple wire) at O2 sensor connector harness, using a 10 MOhm DVM.
=> Should be between 0.3 - 0.6 volts.
=> Over 0.6volts = Open Circuit 413, Faulty Connection, or Faulty ECM
Have you had the transmission worked on? I believe the 413 circuit grounds via a connection to the transmission casing. Not reconnecting that ground, or a bad connection/loose connector at that point might be the cause of your lack of ground at 413.
"Code 13 FSM chart results for step 3.
=> Over 0.6volts = Open Circuit 413, Faulty Connection, or Faulty ECM"
I am not reading .3-.6 volts with the key on. Next I will check at the ECM for that, if that doesn't read .3-.6 then it is the ECM having a problem? I'm heading out to do that now.
The test sounds correct. What I found was I went through 2 sensors. First one due to contaminents on fresh build , second one after relaocating location(bung on collecter). It took out a new one and froze the readings @46 and threw a lean code. Mine seemed to be particularly sensitive to tuning and adjustments. This last one seems to be fine w/the tune being better/stable. don't know if this helps,BTW all are bosch 02's
here is some info on O2 operation that may be helpful:"When you first hook up your ScanMaster, and start your car, you will be convinced either the ScanMaster is broken, or your car is "possessed". Don't worry…… the unit is SUPPOSED to be flashing constantly changing O2 sensor values. The sensor is extremely sensitive at an A/F ratio of 14.7:1. Go very slightly richer than that (14.6:1) and the voltage can soar to 700mV. Go very slightly leaner than 14.7:1 (say 14.8:1) and the sensor output voltage plummets to 200mV. Since the PCM is constantly juggling the fuel up and down to keep it right at 14.7:1, the voltage is going to jump up and down too. So, you will see that, since the PCM updates it's calculations nearly 10 times per second, the O2 sensor voltages are going to be cycling rapidly back and forth between 100 and 800mV, and you might even see values as low as 050 mV, and as high as 950 mV. THIS IS NORMAL."
"Remember, the O2 sensor can only measure OXYGEN. It can't measure fuel, or other components of the exhaust, so if you have a cylinder that misfires, there will be all the oxygen that was in that cylinder, and all the fuel that was in that cylinder, in the exhaust. The sensor will see that oxygen, and the voltage will drop, indicating "lean", but it is not really lean."
"The sensor will see that oxygen, and the voltage will drop, indicating "lean", but it is not really lean."
Mine sticks at .836 V for a few seconds, shows rich. This leads to me to believe the problem is not in a miss, because it would be measuring the extra oxygen and reading lean.
Would a vacuum leak show up as rich or lean? I tried spraying water around the intake but noticed nothing.
This could be three things right? Mechanical (cracked head, vacuum leak?), computer, or ignition related?
Can anyone think of a way to make the problem worse? I tried varying the fuel pressure with no change. Also I tried removing a vacuum line with no changes.
<air> <fuel> <spark>
the good news is you got all 3! Problem is you may have more of <fuel> than the ECM can compensate for. If it were me, I would be looking for leaky fuel injectors. Sounds like your O2 is screaming rich, but your ECM can't lean out your AFR. Also, use carb cleaner or starting fluid to check for vacuum leaks, water may not be enough to notice a small leak.
Sounds like you should consider your O2 sensor as the "messenger" and not the "culprit". Time to look at your fuel equation.
Regarding checking for leaks, will carb cleaner make the engine running faster or slower?
