Pre-Cat Question
Old Jun 18, 2006 | 09:34 PM
CMYC4GO's Avatar
CMYC4GO
Default Pre-Cat Question
Are the pre-cats on these cars as restrictive as the main cat, or are they more restrictive than the main cat? It was my assumption that they are nearly as restrictive, but I was told that they have virtually no restriction at all. I am reinstalling mine tomorrow, in hopes that it will help my little Code 32 problem. I had no codes till I pulled them off. I'm working backwards with this, but I want to find out if the pre-cats had anything to do with the code being set, or if it was just coincidence. I know I probably have an EGR problem somewhere, but if the pre-cats create enough back pressure to make the system work, it might buy me a little time. TIA
BTW...the main cat has been gone for quite some time, so I'm considering that aspect a non-issue.
Old Jun 18, 2006 | 09:57 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Maybe it's cumulative.
Old Jun 18, 2006 | 11:31 PM
bogus's Avatar
bogus
unless you have to keep them, get rid of them.
they are more of a pain in the *** then a real help.
Old Jun 18, 2006 | 11:53 PM
vader86's Avatar
vader86
They do little of the work, you would be better off adding a new main cat back in.
But they are the same 70's era cats, just smaller, so they are as restrictive.
Old Jun 19, 2006 | 08:44 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Any Cat is restrictive unless you have purchased a Super High Flow after market Cat from the industry. If you want to keep your two pre-cat's you could if anything purchase a couple of High flow's to put there instead.
As far as the problem with the code I would agree that it is a coincidence, might be a little something more(not much though)!
Thanks,Matt
Old Jun 19, 2006 | 02:40 PM
CMYC4GO's Avatar
CMYC4GO
Had the OEM y-pipe w/pre-cats reinstalled this morning, took that
%&$# Stage II chip w/EGR delete out.....took it out and drove it all over town on the freeway, using the cruise, and foot.....NO LIGHT/NO CODES!
The car is running cooler, oil temp seems to be down a bit, and no pinging. I probably have a potential EGR problem, I admit, because the removal of the pre-cats/main cat shouldn't have triggered an EGR fault code on a car this old, but this should buy me a little time before I have to get serious about tracking the problem down.
Old Jun 19, 2006 | 08:36 PM
89vert's Avatar
89vert
I removed the pre-cats and main cat on my '89 last year and started triggering a code right away. I added some Seafoam to the tank a couple of times and now no code. I think the Seafoam cleaned the EGR valve. By the way I only put the Seafoam in the tank.
To Pre-Cat Question
