Broken suspension pics…
Old Jun 26, 2006 | 10:59 AM
LT4POWR's Avatar
LT4POWR
Default Broken suspension pics…
While my car was on the lift getting the clutch and u-joints done, we noticed this at the passengers side rear…
Bent camber/spindle/strut rod, and broken upper control rod/trailing arm/dog bone. I’m trying to decide on replacing with OEM or get some of those high dollar VBP/Rippie/EM racing pieces. Has anyone made their own trailing arms? Seems that it wouldn’t be to hard to make some similar to these…
Old Jun 26, 2006 | 11:04 AM
mothersworry's Avatar
mothersworry
I have the VBP stuff and they are great. Give Gary a call and he will take care of you.
Old Jun 26, 2006 | 11:18 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
How do you think they got broken?
Old Jun 26, 2006 | 11:24 AM
LT4POWR's Avatar
LT4POWR
I'm not a 100% sure, but a couple of years ago my car was on a trailer and truck pulling the trailer hydroplaned (slowly) into a guard rail. The car was strapped down in the rear by the camber/spindle/strut rods. I didn't think anything was damaged at the time...been driving/racing it since
Old Jun 26, 2006 | 11:32 AM
comp's Avatar
comp
looks like a new break
Old Jun 26, 2006 | 11:42 AM
LT4POWR's Avatar
LT4POWR
That’s what I thought too…but with the car on the ground, I think it closes that gap. That pic was w/ the car on jack stands, and taken after a 200 mile return trip home from the shop. I guess it could have happened when the shop was pry bar’ing my suspension apart/together…during the u-joint install.
Old Jun 26, 2006 | 12:32 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
that would just pizz me off
Old Jun 26, 2006 | 01:10 PM
Casethecorvetteman's Avatar
Casethecorvetteman
They mustve been prying bloody hard to do that!!
Old Jun 26, 2006 | 01:22 PM
LT4POWR's Avatar
LT4POWR
I don't think they did, I'm pretty sure it (at least the bent camber/spindle/strut rod) happen from the trailer accident.
Old Jun 26, 2006 | 01:30 PM
vader86's Avatar
vader86
Thats got to be a new break, you think that any noise from the rear was the joints or that?
I've been thinking hard about the VBP units, but damn are they expensive.
Old Jun 26, 2006 | 01:42 PM
Casethecorvetteman
Id be leaning more towards that myself...
Old Jun 26, 2006 | 02:04 PM
Kinkajou's Avatar
Kinkajou
I also think it is a very new break. The part is very clean at the break point, I think that driving 100 miles would get dirt easy without doubt.
I also think that the mechanichs screwed up this time!
Just my opinion!
Old Jun 26, 2006 | 02:17 PM
Blownfuel1's Avatar
Blownfuel1
This is just a theory, because I can't see the pic's because I'm at work (D*mn Uncle Sam and his firewall's)Did they replace the driveshaft u-joints, or the half shaft u-joints, or all of the above? If they did the half shaft u-joints, and used a port-o-power to get the half shaft in and out, I could see this happening. Probably the trailering accident though, I had the same basic thing happen with my C-3, everything looked fine till I started it to back it off the trailer when we got home, only to find the steering box case had cracked! One other possibility, they didn't go "Test Drive" (ala "Ferris Bueller's Day Off", did they?) the car after they were done fixing it?
Old Jun 26, 2006 | 02:33 PM
LT4POWR's Avatar
LT4POWR
They did all the u-joints and I was there (in the shop) mostly the whole time, like I said before...I don't think they broke it. They are a highly respected/honest shop.
Old Jun 26, 2006 | 02:35 PM
LT4POWR's Avatar
LT4POWR
I know, too expensive IMO, that's why I was asking if anyone has made any themselves????
Old Jun 26, 2006 | 05:21 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
That upper control arm definately looks like a fresh break. can't imagine you wouldn't feel that under normal driving. Aren't these pieces relatively bullet-proof unless unusually high forces (impacts, etc) are experienced? I just did a full poly conversion in the rear and the spindle rods seem plenty beefy off the car.
Old Jun 26, 2006 | 07:22 PM
Tony.96LT4's Avatar
Tony.96LT4
Made a four link for a 12 bolt chevy rear a few years back. What's going to cost is the Heim (rod) ends. Prices vary with quality. $10-$11for 3/4" standard and $31-$32 for the chromemoly ones. You'll need some tube stock, and left and right handed taps, plus a lathe, and oh yeah, your labor
To Broken suspension pics…
Old Jun 26, 2006 | 11:02 PM
JA94vette's Avatar
JA94vette
I've been wanting to make my own out of aluminum. There is one company that makes the links out of 6061T6 but to be on the safe side I was going to use 7078T6. The only thing i'm missing in the design is what size rod end do they use?? 3/4" for the dog bone links. Would 1/2" work for thoes and 3/4" for the camber and toe links??
Old Jun 27, 2006 | 02:21 PM
LT4POWR's Avatar
LT4POWR
surely someone has made (or had some made) around here
Old Jun 27, 2006 | 03:57 PM
bogus's Avatar
bogus
tow ops need to realize there are tow hooks on these cars.
that damage is inexusable.
