Broken suspension pics…
Old Jul 1, 2006 | 09:45 PM
  #41
LT4POWR's Avatar
LT4POWR
Originally Posted by CentralCoaster
I could see it happening after I put my Energy bushings in there and torquing the rear links down, they would have broke before they rotated. I had to use the bench grinder to get the fitment right.
damn
Old Jul 1, 2006 | 10:16 PM
  #42
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Also, those links look like a much weaker design than the 84-87 ones. Looks like the aluminum ends are hollow and slide over the shafts. The only way that broke was from a siezed bushing, or a serious side impact.
I think the early ones are solid forged pieces.
Old Jul 2, 2006 | 02:37 AM
  #43
JA94vette's Avatar
JA94vette
Originally Posted by LT4POWR
It's in their catalog, and it didn't say the sizes for the trailing arms
Thanks for looking
Does anyone know when they started using the different style dog bones and why? My 94 is the old style and from everything I’ve read, their forged.
Old Jul 2, 2006 | 03:34 AM
  #44
No Go's Avatar
No Go
CentralCoaster: Your issue is a parts incompatibility issue. I used the Energy Suspension bushings on my 96 and had no issues whatsoever.
I find it hard to believe those arms could break under ANY 'normal' circumstances. Someone either pried on them doing work or got into an accident, but seeing as the break is fresh....
Those camber rods are some tough forgings...that was a heck of a hit...bet the camber adjustment would have had enough to correct the slight bend.
Why are you in such a hurry to replace those pieces...they don't do a hole lot...ie installing a set of spherical ones will add more NVH more than anything....set of sticky Nitto 555IIR's would provide a ton more 'performance.'
Old Jul 2, 2006 | 03:52 AM
  #45
CentralCoaster
No, it's a manufacturing issue, and a materials issue, and a lack of understanding about how bushings work issue. I'm willing to bet there's a hefty percentage of guys cruising around with poly bushings that are not working properly for the same reasons, but that's a whole 'nother thread.
What's NVH anyways?
Old Jul 2, 2006 | 08:43 AM
  #46
No Go's Avatar
No Go
Mine popped together like they were made for it...yours don't?
Like I said, a "parts incompatibility issue."
NVH...Noise, Vibration, Harshness...I think OEMs have created new terms now...
Old Jul 2, 2006 | 09:06 AM
  #47
Casethecorvetteman's Avatar
Casethecorvetteman
Mine did too mate, no worries at all. And i tend to
Old Jul 2, 2006 | 12:04 PM
  #48
CentralCoaster
They popped together like they were made for it. Mine slipped in and bolted in just fine, but the dimensions were such that the bolt would tighten down over the bushing face and never against the sleeve, causing the bushing to expand like a test-plug and bind in the suspension. You probably wouldn't notice this problem if it happened on your car.
Please don't assume that it's my inability to install them or buy the right parts. There is one single kit for 84-96 with alternate sizes for the batwing. I'm not going to get into this right now more than I already have. I went through b.s. trying to prove my point to everyone on the tech board, it was a complete waste of time and I don't know if a single guy could comprehend the issue. The tech at Energy did, but all he was willing to do was send another set which I suspected would be exactly the same. So I solved the problem myself by narrowing my control arm eyelets, and heck, I even got crap for that. The problem is fixed, but it could cause something like what's pictured.
Old Jul 2, 2006 | 12:47 PM
  #49
todd_vette87
Guest
Posts: n/a
Central Coaster,
I think i see what you are saying...But wouldn't factory ones also do this? You would hope that one of the GM engineers caught this???
Do you think that the VB&P spherical ends might have any other issues that the regular gear-head might miss(like this one)? I am seriously thinking of getting them to help mount a 88 rear in my 87, I would like to know of any problems BEFORE shelling out about $800 to do all of this.
Old Jul 2, 2006 | 01:07 PM
  #50
CentralCoaster
Originally Posted by todd_vette87
Central Coaster,
It might not be an issue with a rubber bushing of the exact same dimensions because it's more compliant and could take up more compression allowing the sleeve to be clamped and not bind up the joint.
I'm considering going to spherical joints just to do it right and be done with it. Taking baby steps is expensive and wasteful.
Why would you want to mount an 88 rear in your 87? That sounds like a waste of money to me.
Old Jul 2, 2006 | 01:11 PM
  #51
No Go's Avatar
No Go
CentralCoaster: Relax...most know that many variations of parts were used in 13 years of C4 production. I was not inferring you didn't install them right or ordered the incorrect part...hopefully most understand that aftermarket might very well mean-the parts don't fit right/work on all years.
I do my own work. My rear suspension does not bind, etc...except for the lower camber rod with the poly bushing... Still works fine though.
Old Jul 2, 2006 | 01:24 PM
  #52
todd_vette87
Guest
Posts: n/a
Yeah, it is kinda turning out to be a waste of money...I picked it up cheep from a local street rodder wanting to change to a jag???
I thought it would be easier than it is. I thought i would gain larger brakes and get rid of the old style drum emergancy brakes. Pluss the whole rear end is chromed with gold plated calipers. What can i say... i am not much smarter than a fish tasting the shiny lure...
But when all is done there will also be some weight savings(a couple ounches at least) to improve the reaction on the spring(yeah right, who's going to buy that excuse?).
Old Jul 2, 2006 | 01:51 PM
  #53
CentralCoaster
Well, since you already have the parts... the rear suspension only attaches in a few places. If these match from early to late, it shouldn't be a problem. I think the upper shock mounts are different, so you'd want to try and use your old shocks, assuming they'll fit the new style lower shockbolts.
Other than that, the only differences are probably the knuckles, trailing arms+brackets. I've never heard of anyone running out of rear brake, they really don't do much. The halfshafts or axle ends would also be longer as well, to account for the additional trackwidth.
Old Jul 2, 2006 | 02:15 PM
  #54
bogus's Avatar
bogus
I worked on a 92 vert last summer that needed u-joints.
The spindle arm was BENT. It looks like it had been used as a hook point for a roll back. Talk about binding.
I informed the owner it really should be replaced... I donno what he did with it.
Personally, I would want spherical bearings all through the control arms back there.
Old Jul 2, 2006 | 02:24 PM
  #55
todd_vette87
Guest
Posts: n/a
It came with the entire rear end, Center painted(but all new gears and clutch pack); Batwing, half-shafts, knuckles, tow-bars, bearings, camber bars, Even the rotors all chromed, and the calipers gold plated. I found that the hardest part to get so far is the brake hoses. The 88s had a metal tube to clear the emergancy brake with a much shorter hose. I am trying to find some-one who is willing to make me a pair with the longer braided hose. I just switched the shock mounts to the 87. But this did not have the right length trailing arms so i am looking at to VB&P ones to match the the VB&P suspension kit. The remaining 87 parts and busings will go into my 84(it REALLY NEEDS WORK).
Mostly i did it for show since i got it for under a grand and it is all new.
On the brakes...it is just an added excuse. But once i decide on front brake pakage and use your advice of extreme bias spring it MIGHT yeild some gain??? What do you think.
I really want to hear some more here about suspension gains and problems that have been encountered with mods...I am a novice to most suspension geometry and tuning. And this breaking issue has me woried about going to lighter trailing arms. What else might i have missed?
Old Jul 2, 2006 | 02:59 PM
  #56
LT4POWR's Avatar
LT4POWR
http://forums.corvetteforum.com/show...light=dog+bone
