Surge tank explosion
Old Jul 23, 2006 | 07:32 PM
Daddy J's Avatar
Daddy J
Originally Posted by Tom Piper
I think you are right about the surge tank being under pressure causing it to push outward, but this looks like the tank got too hot instead of too cold.
If I remember correctly, R12 will burn under the right circumstances and create phosgen gas.
Could it have ignited?
Tom Piper
As I'm in the plastics business I've been watching this tank post with great interest and the cause has me perplexed.
I think Tom's scenerio has validity. If you look at the edges of the blown out hole you will see that they are smooth. If it was caused by a jet of cold hitting the bottom of the tank the plastic would shatter (plastics get brittle when cold) and we would find sharp edges rather than smooth. Since the edges shown are smooth it is more likely the area was locally heated first and then the coolant pressure blew out through the soft area. This would also extinguish any flame from the R-12.
Since I'm not familiar with R-12. I have no idea as to whether the R-12 igniting makes sense. Thoughts from those familiar with R-12?
Also is there any signs of burning on the bottom of the tank and hoses?
I see some discoloration but that maybe from coolant.
Old Jul 23, 2006 | 08:09 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
thats crazy, what are the odds of that happening?
Old Jul 23, 2006 | 08:19 PM
Mr6spd's Avatar
Mr6spd
Did someone put a propane based refrigerant in the system?
Old Jul 23, 2006 | 08:35 PM
cv67's Avatar
cv67
St. Jude Donor '05
Originally Posted by bogus
I am guessing... lets say the AC line broke a little, letting a high pressure jet of gas make it's way out and essentually burn a hole into the plastic, causing the plastic to rupture.
Toss in a weak spot in the plastic... and BAM! You have a broken surge tank.
Wrong-o, how about this one?
Neighbors monkey gets loose (ya know, Speed Racer had one and it carried a wrench too), and started jacking with the guys car.... the tank with his wrench while gulping down some prime R-12-Made him nuts!! Well, no need to go into details here, you can fuigure out the rest. Trixie was ghey too, from what I hear.
Oh yeah, back to the expansion tank.
Tom Piper's Avatar
Tom Piper
This is the ideal reason why you don't ever want to use refrigerants that are "blends."
Tom Piper
Old Jul 23, 2006 | 08:36 PM
cv67's Avatar
cv67
St. Jude Donor '05
I smacked teh little monkey today too
Old Jul 23, 2006 | 08:48 PM
Daddy J's Avatar
Daddy J
Out of curiosity I looked up the MSDS on R-12. http://www.refrigerants.com/msds/r12.pdf
R-12 apparently isn't flammable, however the refrigerant oil is. Any thoughts about an oil mist flame causing this? I know this explanation is a bit "far out" but having a failure of this kind is "far out" in itself. Any chance of a mist flashback from the hot exhaust headers?
Thoughts?
Added: The "blended refrigerants" have possibilities too. Lord only knows what you are getting today with the recycling equipment
Old Jul 23, 2006 | 11:34 PM
DieL's Avatar
DieL
Thought it would be interesting to note that My A/C stopped working years ago and I had my line break in the EXACT same spot as that. It literally looks identical to your picture. I didnt however have the coolant tank problem. I'll take a closer look at the bottom side of it, perhaps because it's not visible I havn't noticed.
Old Jul 23, 2006 | 11:58 PM
ElisTwoCents's Avatar
ElisTwoCents
St. Jude Donor '05 thru '24
Damn!
Old Jul 24, 2006 | 06:35 AM
Tom Piper's Avatar
Tom Piper
Looking at the picture of the ruptured line, it looks like metal fatigue to me.
Interesting, someone else had it rupture in the same place -- must be pressure on the line or a lot of vibration in that area.
Or, another thought, is the cycling of the AC system causing the evaporator to go hot-cold-hot caused the problem.
Tom Piper
Old Jul 24, 2006 | 04:20 PM
Vetracr's Avatar
Vetracr
The tank failure was clearly heat or chemical related, i.e., internal blow out with smooth melted edges. Something melted or softened the plastic until the internal pressure blew out the reservoir. Possible causes 1) oil in refrigirant flashed and melted or softened plastic 2) refrigirant or refrigirant oil reacted with plastic chemically to soften it, 3) refrigirant and oil at failure point in AC line was under pressure at temperature. Temp and pressure ? but I know it had to be high. A jet of heated oil/refrigirant from a pin hole could easily have melted a hole in reservoir. Once an engineer, always an engineer.
Larry
Old Jul 24, 2006 | 06:03 PM
jburnett's Avatar
jburnett
How about if the electric water pump wasn't working... Ransome sent me an email earlier that said: "Did you perhaps pull the fuse out of the electric water pump?" D'OH!!!! I still can't imagine it exploding like that, not to mention he didn't say anything about it overheating but looks quite possibly like I may be the culprit.
-Jeb
Old Jul 24, 2006 | 09:13 PM
  #33
DieL's Avatar
DieL
Interesting....
Old Aug 13, 2006 | 06:54 PM
  #34
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
Cruise-In II Veteran
Currently Corvette-less
So ~ did you ever figure out what caused this mees Ransome?
~ Purp
Old Aug 13, 2006 | 08:00 PM
  #35
SunCr's Avatar
SunCr
R12 at normal atmosphere's is around -32. Since it blew out at the low side (had it gone at the high, there's usually a nasty hole in the hood), it was probably around 36 to 40 degrees (assuming pressures of 28 to 32 psi) before it hit ambient and dropped to whatever pressure you were above sea level. That immediately flashed it to well below freezing (and it's why you're suppose to wear protective gear when you work around this stuff). Any a/c line will fatigue if you accidently bend one (and it's easy enough to lean on that Evaporator outlet and do that), but it looks like yours went at the weld. That's usually from moisture in the system which gets there if it's not topped off correctly. I would check Bulletins, NHTSA web site for any similar problems - otherwise a Chemical Engineering Firm could probably analyze any oil left in your Drier though it was also contaminated when the line snapped.
Old Aug 13, 2006 | 10:01 PM
  #36
93*Corvette's Avatar
93*Corvette
I think it may be "Al Qaeda" or "Hamas"....
They're have a "Jihad" on your car....
Old Aug 14, 2006 | 12:58 AM
  #37
Ramrod92's Avatar
Ramrod92
Still not 100% sure exactly how it happened, but it was overheating. The digital temp ready was showing a constant 178, but after I heard the pop, the analog gauge was close to being pegged. I need to check, but does the same sensor feed both gauges? The evaporator core actually looked pretty good for being 14 years old.
To Surge tank explosion
Old Aug 14, 2006 | 11:26 AM
  #38
ninetyfivevette's Avatar
ninetyfivevette
No. I believe the sensor on the water pump housing feeds the digital gauge and the sensor in the passenger side head feeds the analog gauge. One of the wires for my Meziere came loose and the analog gauge spiked, but the digital gauge was about 180.
I also had the same fatigue failure on my evap. core. I was pulling on the dryer too much when I was working on it and it snapped in the same place yours did.
Old Aug 14, 2006 | 12:16 PM
  #39
SunCr's Avatar
SunCr
That doesn't look like a stock core unless GM eliminated the foam filter. It's obviously been leaking, so I'm assuming somebody's been topping it off. Get air/water in it and the mix is highly corrosive.
Old Aug 14, 2006 | 05:56 PM
  #40
Ramrod92's Avatar
Ramrod92
I bought the car new and that's the orginal core. I don't recall ever having to charge the system. It always did a good job of cooling the interior down.
