Surge tank explosion
Old Jul 3, 2006 | 10:44 AM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Default Surge tank explosion
Somehow the AC line came loose and sprayed the surge tank while doing 75 mph down the interstate. Here are the results.
Old Jul 3, 2006 | 10:58 AM
jburnett's Avatar
jburnett
Dude...I FU&KING HATE YOUR CAR!!! Why do you think I dubbed it "Christine???"
BTW: I have the surge tank off of my car that I'm not using, I was going to put it on Ebay or the For Sale section here...
-Jeb
Old Jul 3, 2006 | 11:00 AM
jburnett's Avatar
jburnett
-Jeb
PS- Whoops...Double post... See, when it comes to your car it messes EVERYTHING up!!!!
Old Jul 3, 2006 | 11:56 AM
bogus's Avatar
bogus
ohmygod. That's insane!
Old Jul 3, 2006 | 12:02 PM
mseven's Avatar
mseven
WHOA! HOLLY CRAP, is the AC line only held w/dum dum (black crap)or did it break as well?
Old Jul 3, 2006 | 12:08 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
Thats a pretty unusual failure.
The coolest the refrigerant should have gotten was around -32 F if I remeber from my properties table correctly.
Looks like a grenade was in your surge tank.
Old Jul 3, 2006 | 01:34 PM
bogus's Avatar
bogus
the aluminum RUPTURED!!!!!!!!!!!!!
Alvin - calling this an "unusual" failure is the understatement of the decade!!!
Old Jul 3, 2006 | 01:36 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
It ruptured outward though is my point and the temperature 134a makes when you let it sit at atmoshpere isn't that cold at all.... Why did it do this? and why didn't it blow a coolant hose first if it had that much pressure in it.
Old Jul 3, 2006 | 02:14 PM
jimmers's Avatar
jimmers
Thats crazy!!
Old Jul 3, 2006 | 04:00 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Old Jul 3, 2006 | 04:03 PM
Ramrod92's Avatar
Ramrod92
Alvin, it was R12.
Old Jul 3, 2006 | 11:43 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
Alvin, it was R12.
Still, 12 has very simular properties to 134a. Its not like he sprayed it with some liquid nitrogen is my point.
Old Jul 4, 2006 | 04:04 PM
Ramrod92's Avatar
Ramrod92
That seems to be the only conclussion I could come up with. Any one else have any ideads what might have caused this?
Old Jul 23, 2006 | 01:34 PM
Strick's Avatar
Strick
Well that's a new one for me, too. I'll have to talk to my son when he gets back from his vacation. He just took the GM A/C hands on class.
Old Jul 23, 2006 | 01:38 PM
bogus's Avatar
bogus
I am guessing... lets say the AC line broke a little, letting a high pressure jet of gas make it's way out and essentually burn a hole into the plastic, causing the plastic to rupture.
Toss in a weak spot in the plastic... and BAM! You have a broken surge tank.
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Damn...scary.
Old Jul 23, 2006 | 01:40 PM
rick lambert's Avatar
rick lambert
Blockage in one of the lines, very close to the tank, or one of the lines woulda popped?
To Surge tank explosion
Old Jul 23, 2006 | 01:44 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Here's my highly technical explanation. The combination of the hot tank under pressure getting hit with a cold blast in one spot freaked out the molecules in the plastic! I would say now I've seen it all. But I know better than that.
Old Jul 23, 2006 | 07:05 PM
Tom Piper's Avatar
Tom Piper
Originally Posted by Corvette Kid
...The combination of the hot tank under pressure getting hit with a cold blast in one spot ....
I think you are right about the surge tank being under pressure causing it to push outward, but this looks like the tank got too hot instead of too cold.
If I remember correctly, R12 will burn under the right circumstances and create phosgen gas.
Could it have ignited?
Tom Piper
Old Jul 23, 2006 | 07:12 PM
Corvette Kid
Tom Piper
Has no one ever seen something shatter because of an extreme, rapid change in temps? Yes I'm assuming that when the A/C connection failed, it sprayed refrigerant at this location of the tank. If that's indeed what happened, it makes perfect sense to me.
And if that's indeed what happened, of course it would burst outward when the material failed as the tank was under pressure. Am I missing something here?
