Code C43
Old Jul 4, 2006 | 01:45 AM
jabez's Avatar
jabez
Default Code C43
On a 1992.
What is that?
Old Jul 4, 2006 | 02:46 AM
slicked25's Avatar
slicked25
Code 43 is knock sensors.
Old Jul 4, 2006 | 08:45 AM
MikeC4's Avatar
MikeC4
with CA gas prices skyrocketing, are you running lower octane fuel which will give put your knock sensor to the test?
Old Jul 4, 2006 | 09:02 AM
jabez's Avatar
jabez
uhhh...no . running 91 octane.
Old Jul 4, 2006 | 01:06 PM
bogus's Avatar
bogus
I would say you need to check the wiring, and worst case, replace the knock sensors.
Old Jul 4, 2006 | 08:48 PM
jabez's Avatar
jabez
Whats a knock sensor cost?
Old Jul 4, 2006 | 08:59 PM
MikeC4's Avatar
MikeC4
about $30 from Ecklers.
http://www.ecklers.com/find.asp?
Old Jul 4, 2006 | 10:41 PM
bogus's Avatar
bogus
cheaper from NAPA.
Old Jul 5, 2006 | 10:45 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Don't get the cheapie Bosch from AutoZone. Use only Denso or AC/Delco/Delphi or you might be sorry.
http://www.buyautoparts.com/gm-parts/
And don't throw money at parts. Make sure you have a defective 02 sensor and don't assume one or both of them (your LT1 has two) have gone ****-up. This is where an 02 sensor test tool or a scan tool comes in handy and pays for itself.
Old Jul 5, 2006 | 04:36 PM
jabez's Avatar
jabez
I am only getting the SES light only when I start her up. After two or three minutes of driving the SES light disappears. Drives fine.
Old Jul 6, 2006 | 08:17 AM
onedef92's Avatar
onedef92
Inspect the connectors then. Sometimes they get fouled with oil and grime this will cause them to throw a code. That was the case on my Vette.
Old Jul 6, 2006 | 12:52 PM
MTVette's Avatar
MTVette
On the other hand, my 92 was throwing Code 43's and lighting the SES light intermittently upon startup. A replacement of the knock sensors permanently fixed the problem.
To Code C43
