Ignition Coil?
Old Jul 6, 2006 | 09:13 PM
Mallett Z's Avatar
Mallett Z
2015 C5 of the Year Finalist
St. Jude Donor '07-'08-'09
Default Ignition Coil?
Hello, this may be a dumb question but i cant find the ignition coil to see if i bought the right one. I got an MSD perf. coil (part 8226) they guys at the store werent 100% sure if this is the one i need or if it is the other. well i went to go look to see if it matched tonight and i cant find it. is it in plain sight or did i just not look hard enough? or does anybody off hand know if this is the right part thanks in advance
Car: 96 LT4
Old Jul 6, 2006 | 09:23 PM
STL94LT1's Avatar
STL94LT1
It's bolted to the front of the passenger side cylinder head.
Old Jul 6, 2006 | 10:35 PM
Mallett Z's Avatar
Mallett Z
Yep, i looked over it. and of course i picked the wrong coil, i figured that would happen. Thanks for the help
Old Jul 7, 2006 | 06:15 AM
Tom Piper's Avatar
Tom Piper
The '96 coil is different than the previous years.
The '96 coil should be used with the '96 ignition module.
Tom Piper
Old Jul 7, 2006 | 11:11 AM
MarkBychowski's Avatar
MarkBychowski
Tom Piper
Old Jul 9, 2006 | 02:27 AM
Mallett Z's Avatar
Mallett Z
Tom Piper
so is it no good without the other?
Old Jul 10, 2006 | 06:27 AM
Tom Piper's Avatar
Tom Piper
I don't know if I would use the words "no good."
But, the '96 ignition system was designed to be optimized as a matched set.
The stock '96 coil is a hotter coil (less primary impedence) than previous years.
Tom Piper
Old Jul 10, 2006 | 08:08 PM
~db~'s Avatar
~db~
I am using and have been using the MSD red perf coil for a year now WITHOUT the module with no problems. But now that it's been mentioned, I will have to look into it and see if I should just replace the module as well
Old Jul 10, 2006 | 08:18 PM
rickneworleansla's Avatar
rickneworleansla
Maybe you could answer my MSD install question for my 95 in the thread below.
http://forums.corvetteforum.com/show....php?t=1433843
To Ignition Coil?
