Alternator mounting question
Old Sep 2, 2001 | 02:02 AM
NoWorries's Avatar
NoWorries
Default Alternator mounting question
Ok, on an '87 L98, you have three points of mount for the Alternator:
1. Power Steering Bracket
2. Bracket coming from the Smog Pump
3. Bolted to the Exhaust Manifold
Now...say you have headers and you can no longer bolt up that third mount? I spent a whole lot of time jerry rigging the oil dipstick tube to work and the alt is going to be a lot more work...
In all theory, the two mounts are plenty enough...I've wiggled and yanked and pushed and pulled and it feels about as steady as an alternator can be...
Those with headers, what'd you do with your alternator? Thanks.
Old Sep 2, 2001 | 08:05 AM
NoWorries's Avatar
NoWorries
Default Re: Alternator mounting question (NoWorries)
TTT
Old Sep 2, 2001 | 05:33 PM
NoWorries's Avatar
NoWorries
One more time ^
Old Sep 2, 2001 | 08:21 PM
BiZ's Avatar
BiZ
I don't have headers. But I do have the smog pump eliminator. With it installed it moves the alternator closer to the L/F wheel, thus making the exhaust manifold bracket too short. Doesn't seem to be a problem.
[Modified by BiZ, 7:21 PM 9/2/2001]
Old Sep 2, 2001 | 08:34 PM
corvette1990's Avatar
corvette1990
Well on my 1990 with the TPIS Headers, they used the stock bolts. The stock Alternator burned up 1200 miles later. I am wondering if that rear bar/bracket is transfering high heat to back of alternator where the board of diodes are, that regulate the voltage. When just switching to new reman unit I was wondering I could do away with that bracket too. Let us know if you throw a belt or wear the bearings on the Alt from pulling.
Chris
Old Sep 2, 2001 | 09:08 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:cheers:
LPE Headers tell you you can leave the bracket off. I've had it off all summer, no problems.
:seeya
Old Sep 3, 2001 | 01:59 AM
NoWorries's Avatar
NoWorries
Default Re: Alternator mounting question (jackdaroofer)
Thanks for the replies, thats just what I wanted to hear.
To Alternator mounting question
