air condition
Old Jul 11, 2006 | 08:11 AM
snowfun3's Avatar
snowfun3
Cruising
Default air condition
can anbody give me some ideas on why my 96 LT4 upper blower vents dont work.i only get air out the bottom, any info would be greatly appreciated, thanks
Old Jul 11, 2006 | 02:13 PM
rayosequis's Avatar
rayosequis
Check the vaccum lines that run near the battery. On my '94 the plastic lines had worn through from rubbing on one of the battery terminals. Are you also having problems with your cruise control ? You need to check the vaccum lines that run to that as well.
Old Jul 12, 2006 | 08:11 AM
snowfun3's Avatar
snowfun3
Cruising
cruise does work, i looked around there and eveything looked ok but i will look closer. thanks
To air condition
