Selective Ride Codes
Old Jul 14, 2006 | 03:10 PM
Jayman's Avatar
Jayman
Default Selective Ride Codes
Hi guys and gals.
1. Which pins do I jump for codes on my 89 6 spd? I'm thinking it should still be A - B but I wanted to be sure? The reason I ask is the codes for the SES and the Selective ride flash at the same time. Do I ignore the SES and read what I want then?
2. What is the procedure for clearing these codes from the systems computer?
Thanks all!
Old Jul 14, 2006 | 08:18 PM
RRT vette's Avatar
RRT vette
Read this and see where it gets you...
http://forums.corvetteforum.com/show....php?t=1444343
Old Jul 15, 2006 | 03:38 AM
Jayman's Avatar
Jayman
Okay thanks but maybe I'm missing something here. I read through all the linked info (some don't work) and it says nothing that I can find about selective ride codes and how to clear them.
Old Jul 18, 2006 | 03:00 AM
Jayman's Avatar
Jayman
ttt
Old Jul 19, 2006 | 10:53 PM
Daddy J's Avatar
Daddy J
Here's the procedure for clearing the FX3 codes which I saved from a post by C4 Cruiser
Code Clearing
Codes are cleared by having the ignition set to "RUN" and grounding pin "C" in the ALDL for two seconds and repeat this two more times for a total of 3 times.
FX3 codes are stored like history codes and they cannot be cleared by disconnecting the battery.
1. Ignition to run
2. Ground A to C hold for 1 sec
3. Wait two seconds
4. Ground A to C hold for 1 sec
5. Wait two seconds
6. Ground A to C hold for 1 sec
7. Remove jumper
8. Turn key to off position
9. Wait for 2 seconds
10. Codes cleared.
If the light comes back then most likely the problem still exists
Old Jul 20, 2006 | 01:54 AM
Jayman's Avatar
Jayman
Thank you Daddy J, I'll give a shot.
Old Jul 20, 2006 | 02:05 PM
Jayman's Avatar
Jayman
Code Clearing
1. Ignition to run
3. Wait two seconds
5. Wait two seconds
7. Remove jumper
10. Codes cleared.
It worked and no light so far!!!
Thank you sir I appreciate it.
Jayman
To Selective Ride Codes
