CAGS Disablement 95' ZF
Jul 19, 2006 | 02:43 PM
I heard there was a harness or something under the hood right side that you unplug to eliminate the CAGS ......?
I allways thought it was on the left side of the trans.?
Which is it?
Thanx
Jul 19, 2006 | 03:11 PM
its on the drivers side of the trans...
left side if you're in the car, right side if your in front looking at the hood...
all about perspective.
Jul 19, 2006 | 03:19 PM
Let me refraise it..Is it under the hood or beneath on the transmission?
Thanx
Jul 19, 2006 | 04:01 PM
Jul 19, 2006 | 04:05 PM
From: One day you're a Comet...the next day you're dust... Arkansas
I disabled mine first thing. What a PITA!
Jul 19, 2006 | 05:11 PM
Quote:
Originally Posted by donhall
On my 93, there is a CAGS relay located under the hood, passenger side, attached to the rear of the wheel liner.
I found 2 of them Checked in the shop manual can't seem to find which one is which.Not under CAGS or Relays or Transmission section.
Any suggestions?
Jul 19, 2006 | 05:26 PM
My 93 manual has the location under - RELAY: 2nd and 3rd gear block out relay---- section 6E3-CB (pics in second book of manual)
Your right..I found it same page in my book.
Thanx Guys...You've saved me alot of time.
Jul 19, 2006 | 08:43 PM
Just unplug it at the trans, no muss, no fuss, no codes, no CAGS!
Jul 19, 2006 | 08:44 PM
Get your Vette up in the air and look on the driver's side of the trans.
Look for the solenoid.It has the 2 wires coming out of it, should be black and white wires.That is the 1-4 solenoid. Just unplug it.
Give a visual inspection to the rest of the underside.
