code 26
Old Jul 19, 2006 | 09:05 PM
Ibuyvettes's Avatar
Ibuyvettes
Default code 26
Ok on a 92 LT1 corvette, what do I do with a code 26 (qaud driver)?
Old Jul 19, 2006 | 10:13 PM
ultraviolet70's Avatar
ultraviolet70
The quad driver contols 4 circuits as quad implies. What you need to do is check those items. They are the EGR solenoid, EVAP canister purge soleniod, air pump control relay and the ESV valve (electronic switching valve-it controls the air flow from the AIR pump. I'll bet one of these 4 items failed, the only other thing is the ECM, but every time I've seen a quad driver code it's been one of the components, not the ECM.
Old Jul 19, 2006 | 10:52 PM
Ibuyvettes's Avatar
Ibuyvettes
where is the purge solenoid?
Old Jul 20, 2006 | 11:46 AM
ultraviolet70
I think?? right side of intake. Should have 2 wire connector and 2 vaccum lines (one from intake and one to the EVAP system).
To code 26
