5 spd Auto Trans?
Old Jul 21, 2006 | 09:45 AM
YellowFvr1's Avatar
YellowFvr1
Default 5 spd Auto Trans?
Do we have any options as far as swapping any sort of 5 speed auto into an lt1 vette? I'd love to be able to have a built 5 spd, too much room between the 2nd and 3rd gear shiftpoints in my 4 spd.
Old Jul 21, 2006 | 10:16 AM
bogus's Avatar
bogus
I don't think any exist that will fit our car.
The only A5 I can think of is the one used in the latest RWD caddies... but I have no idea if those can be adapted.
The 4L60E and 4L65E was used in all sorts of high-torque GM rear drive cars, Corvette (up until recently), F-Bodies and GTO. Trucks used the 4L80E.
The latest vette uses a 6spd auto, but with the rear mounted transmission, I have no faith it would ever fit.
Old Jul 21, 2006 | 10:21 AM
YellowFvr1's Avatar
YellowFvr1
yea I'd kill to be able to fit one more gear in my 4L60E. i hate the idea of shifting out of second around 90 mph and not getting to the top of 3rd until 145+
Old Jul 21, 2006 | 12:25 PM
bogus's Avatar
bogus
they get away with it because of torque...
what rear gear do you have? It sounds like you have 2.59s, you might consider something taller than say, 3.45.
Or, upgrading to a D44 with 3.45s in it.
Old Jul 21, 2006 | 12:32 PM
YellowFvr1's Avatar
YellowFvr1
with 18 inch 315 rear tires and 3.45 rear gears with a 6500 rpm redline you're shifting from 2nd at 88 and 3rd at 143
Old Jul 21, 2006 | 12:35 PM
Pete K's Avatar
Pete K
A gearset is rumored to exist for the 700/4l60e that is similar to the turbo 350
Old Jul 21, 2006 | 05:43 PM
YellowFvr1's Avatar
YellowFvr1
go on......
Old Jul 21, 2006 | 05:53 PM
Pete K's Avatar
Pete K
I have not found the rumored gearset. I heard that a shop in the Bronx, New york has them for sale. I have not located them though. If I find a set, I will buy them and install them for r&d purposes. If anyone else knows how to get them, please post.
Old Jul 21, 2006 | 07:24 PM
CFI-EFI's Avatar
CFI-EFI
If it any clue, the lower (alternate) gear ratios for the TH400 were intended for a TH475 for trucks. Maybe there is some sort of a parallel situation for the 700R4. Of course, there always is the 200R4. It has a higher first gear and consequently, closer splits between the gears.
RACE ON!!!
Old Jul 21, 2006 | 07:38 PM
bogus's Avatar
bogus
how easy is it to adapt a 200R4 into a C4? I have no recollection of someone doing this.
Old Jul 21, 2006 | 10:33 PM
Pete K's Avatar
Pete K
I would imagine it would be tough. The 2004r has no removable tailhousing. It is cast into the case.
Old Jul 21, 2006 | 10:39 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I have a 5 speed auto in my Power Wagon(actually I'm told it's really a six speed with two second gears, how that happened I don't know).
Old Jul 22, 2006 | 01:19 AM
bogus's Avatar
bogus
Mojo - that 5spd is a pretty clever piece of Mercedes engineering.
It has an extra cog for downshifting, IIRC. I can ask my bud Travis, he can explain it for me.
Old Jul 22, 2006 | 09:30 AM
AKS Racing's Avatar
AKS Racing
Bruce Witherspoon discusses having a 200R4 in his L-98 C4 in the "drag suspension" post above for use in a NHRA specific class.
Aaron
Old Jul 22, 2006 | 09:33 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
In that case, the L460E in my Chevy van has four third gears....and they are all a different ratio!!!
Larry
code5coupe
To 5 spd Auto Trans?
