For the life of me I can't remember or find what engine vacumn should be. While I was looking in the FSM I saw where they recommend using a Back Pressure guage on the 02 bung to check for restricted exhaust,
anyone have one of these things, I would have thought it could be checked with a regulator vac. guage?
I'd be tempted to fire it up for a few seconds without an O2 sensor installed just to see what it was doing. I'd think that if the exhaust was flowing properly you'd have a bit of pulsing at the bung, but if it were restricted you'd be blowing exhaust out the opening like crazy. A little Bubba, for sure, but it'll give you a clue.
holy poop, that puppies expensive, but thanks for the post. I just thought it would be an easy way to eliminate or confirm a possible clogged cat. I'm not having any problems now, but the cat is always in the back of my head.Heck, if it were 30-40 bucks, I'd have one.
i have used a Sears vac/fuel pressure gauge,,,,,had engine warm ,hooked it onto the fitting went to full throttle then a quick power brake then the heat started on the rubber hose,,,, if i had a foot of braided line on it i could have drove it
Be a nice tool for a vette club to have...few guys could chip in a few bucks and pass it around if someone thought they might have a clogged cat.Sure would be easier than dropping the exhaust.
Ye olde timey vacuum gauge had a 10 or 15 pound pressure reading on the other side of zero, for checking the fuel pressure of mechanical fuel pumps. I'm sure these must still be available. Look where cheaper gages are sold, like J.C Whitney (where I bought mine, a hundred years ago) or Harbor Freight.
I think I still have the gauge I made in my tool box. All you need is an old fuel pressure gauge that reads up to 5 psi. To prevent the gauge from cooking I plumbed the gauge with a coil of copper pipe into the O2 sensor bung. Anything over 2 psi through the cats at idle and its time for a replacement. Good luck.
I guess you and I are the only one old enough to remember JC Whitney
CFI-EFI but that is interesting, I'll look.
Believe it it not, they are still alive and kicking. Check IT out. They have moved, about 100 miles West Southwest, off of Interstate 80 to La Salle, Illinois. Back in the day I made a foray, or two, deep into the city, to State and Archer, to pick up parts for my 1929 Model A.
Originally Posted by rick lambert
Guess I'll take a look for an old fuel pressure guage..I just thought it had to show a negative like CFI-EFI said.
The vacuum gauge is the negative, side (pressure below atmospheric). The few pounds on the other side of zero, is the positive pressure, (pressure above atmospheric) of the mechanical fuel pump pressure gauge. Remember, too, pressure is pressure. You can forget the name of the fluid named on the face of the gauge, if you can remember what you have it attached to. I have a 0-60 psi, bicycle tire pressure gauge that I use for my fuel pressure.
To check my exhaust back pressure I just use a sears vacuum/fuel pressure gauge. I tap the exhaust with a 1/8 pipe plug and then use a brake line compression fitting for 3/16 line and screw it into the exhaust pipe and then attach a 2 foot length of steel brake line to the compression fitting. The two foot piece of brake line eliminates the heat in the brake line and then I attach the rubber hose to the brake line and route it through the window to my gauge in the car. Take the car for a spin and see what the backpressure is at WOT at all RPM ranges. After testing is complete I put a 1/8 pipe plug in the exhaust.
What kind of psi are you seeing at 5K RPM and up at WOT?
The lower the better, my current car has 1-1/4 PSI at WOT. The same car used to have 3 PSI at WOT and when I redid the exhaust to the current configuration that gave me 1-1/4 PSI the car picked up 32 RWHP with no other changes.
How much power do you think is left on the table at just under 6 psi?
This reading was at 6K in 2nd Gear WOT. I have no cats, but full exhaust with mufflers. I have known this to be a problem for some time, but have not attempted to resolve.
I'll be damned CFI-EFI, you remember the monthly catalogs?
I still get them. I think they are quarterly, or semi-annual, now. I haven't bought from them since the late fifties or early sixties. Did you see my PS. and the link to the Harbor Freight gauge?
