I'm screwed....
Old Jul 22, 2006 | 11:09 PM
bogus's Avatar
bogus
remove the rail from the intake, and turn on the key... watch what flows out.
before you do start the car, be sure to squirt a little oil into each cylinder, and crank it without spark or plugs installed. This will allow for the excess fuel to blow out.
Old Jul 22, 2006 | 11:11 PM
bogus's Avatar
bogus
Originally Posted by Corvette Kid
Yes and so that is how it maintains pressure. If it fails it will simply not allow this. I suppose perhaps it's possible, but I've never heard of or run across one failing and causing excessive pressure.
That just sounds backwards to me.
The pump can deliver about 100 PSI.
The FPR steps that down to 40 PSI.
What happens when the FPR can't contain the pressure any longer?
Old Jul 22, 2006 | 11:12 PM
JustForFun's Avatar
JustForFun
i had same thing happen to me other week. Come to find out, the injector harness was grounding out against the block (rubbed wire) and was holding injectors open. wiggle the injector harness and see if you get pressure, or with key on and engine off see if you can make the injectors click/fire
left me stranded couple times. My symptoms were exact as yours.
I also flooded my engine...no issue after getting oil changed
Old Jul 23, 2006 | 12:13 AM
silver86's Avatar
silver86
This is kind of interesting. I was just taking off from a light when she died on me. I had no miss or rough idle to indicate that one or more cylinders were fouling out. It was like someone flicked a switch...or all the injectors flooded all cylinders at once. I actually thought my coil or ICM had gone out. I'll check the harness before beginning the disassembly tomorrow. Maybe the problem is just this simple, huh?
Old Jul 23, 2006 | 01:46 AM
jfb's Avatar
jfb
You have one or more injectors held open either because a defective injector/s or a wire grounded or defective ECM injector driver holding the injector wire to ground. That is the only way to get gas into a cylinder, through an injector. All cylinders had gas because the 86 does batch fire with the injectors, not sequential fire.
Old Jul 23, 2006 | 06:29 AM
86PACER's Avatar
86PACER
And make sure that the main connector to the distributor is connected ( the multi terminal one at the base), or you will get no fuel spray from the injectors when you turn the key. The computer needs an RPM signal from the pick up coil in the distributor in order to allow this. This is for an L98.
Doing this test should tell you something. When you ohm test an injector, it only tells you part of the story. It won't tell you anything about leaks or bad spray patterns. A visual inspection of the injector nozzles under fuel spray is needed.
Old Jul 23, 2006 | 06:50 AM
comp's Avatar
comp
best of luck,,,it won't have any sludge inside is a plus if all is well
Old Jul 23, 2006 | 09:38 AM
honda hunter's Avatar
honda hunter
Some really good info in this thread. I look foward to seeing how it all works out. Good luck.
Old Jul 23, 2006 | 10:47 AM
silver86's Avatar
silver86
A-ha! A clue! I went out this morning and pulled off all of the injector harnesses. Now I've got pressure at the rail. It's still falling. So, I pulled the plugs, rolled up some shop towels really tight, and stuck them into the plug holes. As the pressure drops, I'll check the towel to see which cylinder is still receiving fuel (since none should).
There is some great info here, thanks guys for all of the input. I will keep everyone posted.
For what it's worth, these are brand new FMS 42# injectors, with a brand new Walbro 225 lph fuel pump, sock and filter. I did use a used AFPR, so that may certainly be a weak point.
Old Jul 23, 2006 | 12:06 PM
silver86's Avatar
silver86
Results: I built the pressure back into the rail to 30#. With the shop towels inserted in the plug holes, I waited for the pressure to drop significantly (I checked the towel at around 9#). Cylinders 4 and 5 were wet with fuel. Now a question: If the cold start injector was bad and leaking, would the fuel primarily flow to these cylinders as it dripped from the injector?
Old Jul 23, 2006 | 12:30 PM
rick lambert's Avatar
rick lambert
I'd bet the farm it's not the cold start injector. What I'd suggest is Ohming the injectors. And it seems to me if the regulator were bad you would eventually lose all pressure...I'll stick with what I first said, bad injector(s) I think you have a few sticking open. If you read the section in your FSM about how a cold start injector works...you'd see why I bet against that.
Old Jul 23, 2006 | 01:55 PM
bogus's Avatar
bogus
we don't know what intake valves are open right now.
The theory sorta stands up, but with valves in various degrees of open, it's not proving everything. Remove the rail and try this again.
Old Jul 23, 2006 | 02:48 PM
  #33
silver86's Avatar
silver86
I ohm'd the injectors. If I did this right (and, hey, that's debatable: I used the resistance setting 2000 on my volmeter). All injectors are 16 except the start injector which is 5. If the wifey lets me, I'll pull the rail later today (I'm on that proverbial thin ice since I've been out there the better part of two weekends).
Old Jul 23, 2006 | 02:57 PM
  #34
rick lambert
Well, that proves the injector coils are fine...don't think that actually proves none are sticking open or leaking though.
HEY, I'm always on thin ice with the wifey..after 37 years think she'd get used to it.
Old Jul 23, 2006 | 03:26 PM
  #35
silver86's Avatar
silver86
So 5 ohm resistance is ok for the start injector? I'm going to pull the rail here in a few minutes. I'm going to pressurize the rail, with the harnesses removed and look for leaks. After, I'll reattach the harnesses and pressurize the system to see if any are sticking open.
I'm resurfacing a set of ZR-1 rims at the same time. Too little time......
