I'm screwed....
Old Jul 22, 2006 | 04:03 PM
silver86's Avatar
silver86
Default I'm screwed....
Alright, the thing died on me about two weeks ago and I had to get it towed home. I saw a fuel leak when the guy was putting it on the truck, so I replaced the rubber parts of the fuel lines. Then, lo and behold, today I found out everything I wanted to know about Hydro-lock. So, I pull the oil dipstick, and its soaked in fuel, no oil anywhere. I drain the pan....must've been at least 1/2 gallon of gas in there.
Now, I'm pissed. This blower setup is almost done, and now I gotta rebuild the entire engine......
Old Jul 22, 2006 | 04:22 PM
rick lambert's Avatar
rick lambert
that probably is why your fuel pressure in another post looked bad (I responded) about the hydro lock, before I tore into it I'd change the oil and fire it up..you might be lucky, no knocks I'd take it for a nice soft drive.Good luck.
Old Jul 22, 2006 | 04:32 PM
silver86's Avatar
silver86
I'll give it a shot. How does something like that happen? Fuel blows by the rings? Blown head gasket?
Old Jul 22, 2006 | 04:33 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Well if you do, at least it'll be clean on the inside.... I'm guessing you may fail to see the humor there. But what makes you think the engine's wasted? Have you tried putting some oil back in it and restarting it? Bogus had a similar situation occur when (I believe) a FPR failed on him. I'm pretty sure he saved the engine, if my foggy old memory serves me right. I've had diesels come in the shop with so much fuel in the oil that I had to have two drain pans ready to catch all the liquid. On an average system fill of 10 gallons (yes, 10 gallons) on these engines, I've seen double that or maybe even more come out. After I fixed the problem that caused the leakage, they all lived to see another day.
Old Jul 22, 2006 | 04:38 PM
silver86's Avatar
silver86
Maybe I'm being an alarmist. Before this, I'd never even heard of hydrolocking. Off to get some oil I guess....
Old Jul 22, 2006 | 04:50 PM
Corvette Kid
Nothing unusual about getting a little freaked out in such a situation. Damage is possible but rare. If it works, change the oil again in short order. This should get any remaining gas contamination out of the system. I wish you the best!
Oh, and of course troubleshoot and cure the problem that caused this!
Old Jul 22, 2006 | 04:59 PM
bogus's Avatar
bogus
the kid is right, my FPR failed, dumping fuel in through the vacuum line.
I had 2 cylinders FULL and a crank case with about 3 gallons of **** in it.
That was 14 months ago, and no problems.
Old Jul 22, 2006 | 05:06 PM
silver86's Avatar
silver86
I pulled the vacuum line from the FPR, and not even a hint of fuel smell (well, outside of fuel being all over the garage now). I'm guessing I've got some injector issues, but these are brand new FMS 42#'ers.
So, I'm gonna put some new fuel in there, and start troubleshooting this ****er. Any idea where I should start?
(By the way, thanks for all the input!)
Old Jul 22, 2006 | 05:17 PM
Corvette Kid
There's a great tech tip in C4 Tech Tips on troubleshooting such problems. And now that Andy (Bogus) has checked in, he'll walk you through every step too, with his experience in this matter.
Old Jul 22, 2006 | 05:30 PM
WEH 2000C5's Avatar
WEH 2000C5
We used to have a switch in the cockpit on the big radial aircraft engines to dilute the oil on shut down in frigid temps. We'd pumped gallons of aviation gas into the crankcase oil to thin it as we taxied in , so it would turn over in the morning . after start-up the next morning , we would run up the engines to evaporate the fuel before takeoff. SOP , no ill effects on the engines.
Warren.
Old Jul 22, 2006 | 05:36 PM
Corvette Kid
Warren.
Interesting! As a mechanic, I might have been a little paranoid if you'd have told me that as we were taking off the next morning. Obviously it was a pretty safe procedure. You fly-boys can't afford to take chances.
Old Jul 22, 2006 | 06:28 PM
rick lambert
Well the way your FP was dropping I think you do have injector(s) problems.
Old Jul 22, 2006 | 08:33 PM
silver86's Avatar
silver86
Here's something interesting: I've emptied the engine of fuel (drain pan and cylinders), now when I turn the key over to get the fuel system to prime, I get no rail pressure. There is fuel on the plugs, but no pressure. I've also switched out the prom I was running to a different prom (one for 30# injectors instead of the 40 that I was running).
Old Jul 22, 2006 | 09:15 PM
bogus's Avatar
bogus
the prom won't effect the pumping action or pressure at the rail.
I wonder if the fuel pump spun a gasket, so to speak, and decided to die by dumping huge volumes of gas...
You need to check the fuel pump and filter.
Old Jul 22, 2006 | 09:32 PM
Corvette Kid
A bad FPR can cause a rapid drop off too.
Old Jul 22, 2006 | 09:35 PM
bogus's Avatar
bogus
If the FPR was bad, I would expect the pressure to rise through the roof. it isn't controlling the pressure any longer.
As I understand it, the FPR is a restricting device...
Old Jul 22, 2006 | 09:58 PM
Corvette Kid
Yes and so that is how it maintains pressure. If it fails it will simply not allow this. I suppose perhaps it's possible, but I've never heard of or run across one failing and causing excessive pressure.
To I'm screwed....
Old Jul 22, 2006 | 10:03 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Not cool! I'm sorry to here about your loss. Maybe you could go with a 383 instead, I saw your blowere for sale in the parts section I hope all goes well keep us posted as to your progress!
Thanks,Matt
Old Jul 22, 2006 | 10:17 PM
rick lambert
Well, he posted his fuel pressure in another post, and if the FPR goes bad he will definetly lose pressure, but not like he posted, which leads me to believe he has some injector(s) not all, but some sticking open.
Old Jul 22, 2006 | 10:18 PM
cplonner's Avatar
cplonner
If it comes to it and you have to get a new engine I found several places to get really good high powered engines. I bet its the fuel pump or the injectors. Possibly both. Its problably more of a head ache than a disaster.
