LH headlight removal question
Old Jul 22, 2006 | 08:50 PM
BLKBTY's Avatar
BLKBTY
Default LH headlight removal question
Help! I started to remove the drivers side headlight assembly to rebuild the motor. I removed all the nuts and screws as desribed in corvette magazine, but I ran into a snag. There is a small bracket attached to the one stud for the headlight and it's also attached to another bracket. I loosened the bracket to take it off, but both studs won't aloow me to remove it. Must I remove some other bracket that will allow me to remove the headlight assembly.
Thank You
Blkbty
Old Jul 22, 2006 | 10:17 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I did this same fix on my Vette and didn't get any snags. I would be able to help if you had a picture of what your describing so I can look at mine and coordinate back. If you can post a pic do so!
Thanks,Matt
Old Jul 24, 2006 | 06:39 PM
BLKBTY's Avatar
BLKBTY
I can't post attachments because I'm just a junior member. The bracket in question is a cupped shaped bracket with a stud. The stud goes through the hood hinge bracket and over the stud coming from the hood bracket. I hope I don't have to remove the hood hinge bracket. Can you look and see if you did this? My car is a 89 coupe.
Old Jul 24, 2006 | 06:51 PM
madmatt9471
Only thing I can do is direct you to these two sites on the fixes w/picture(I don't know what year your Vette is!)
http://www.corvettemagazine.com/2001...ghts/head1.asp
http://www.corvettemagazine.com/2002...hts/light1.asp
Thanks,Matt
To LH headlight removal question
