fuel pump question
Old Jul 24, 2006 | 08:04 AM
alx's Avatar
alx
Default fuel pump question
Hello.My car is Vette with LT-1 engine,42lb injectors & Procharger with 15psi.What fuel pump is better for this application?How much lph is stock pump?
Thank you.Alex.
Old Jul 24, 2006 | 09:18 AM
divette's Avatar
divette
Default fuel pump
Thank you.Alex.
еще раз Hello
for this setup - Holley/Walbro 255lph (in-tank mount) т.е.вместо штатного
stock is 160 lph
255 тебе хватит с головой
Old Jul 24, 2006 | 09:54 AM
alx's Avatar
alx
Привет.А Caroll из Blowerworks говорит,что надо ставить 2 по 255.Один в бак,другой снаружи.Для чего два?Давление или объем топлива недолжны измениться.А длячего тогда?
Old Jul 24, 2006 | 02:48 PM
lcvette's Avatar
lcvette
I don't know what that says.... but I saw Blowerworks....255.... and some symbols.. if ya talked to Greg.. you are on the right track.. also Brand-x is a phenominal guy to deal with.. can't say enough about either one of them when dealing with blowers..
Chris
ps.. for the max of the intank 255, I was able to squeeze 514/570 out but she was going lean very quick at the end.. this was at 14.5 psi and fuel pressure was I would not feel comfortabl;e running more then 500rwhp with a single intank 255 and nothing else. you may also look into the kenne bell boosta-pump which I have seen guys use successfully to 600rwhp.. but again.. when it comes to fuel......... after all my ordeals.. I would rather go overkill and have room left over a few hundred rwhp to grow then be right at the max output and run the risk of it going lean and detonating.
Chris
Old Jul 24, 2006 | 07:02 PM
divette's Avatar
divette
он безсовестно тебя грузит.....
2 по 255 я себе поставил - НО У МЕНЯ ТВИН-ТУРБО с давлением 22-25 пси
и мне их прекрасно хватит (это-то при 70-ых инжекторах!)
а тебе на 42-ых да 15 пси одного 255-ого ЗА ГЛАЗА. ПОВЕРЬ.
...а так с-дуру можно и десять насосов поставить - хуже не будет
один 255-ый = 600 нр
Old Jul 25, 2006 | 02:27 AM
alx's Avatar
alx
Понял спасибо.У тебя какие характеристики по разгону и 400 м.Какие изменения в трансмиссии?если можно то оставь свой e-mail,а то этих болванов когда спрашиваешь ,сам знаешь какие они.....Мой e-mail
alx2010@mail.ru.Когда настраиваешь,какими приборами пользуешся чтобы отрегулировать air/fuel ratio & knock?
Я из Астрахани.
Old Jul 25, 2006 | 03:05 PM
alx's Avatar
alx
What fuel filters are you use with 255 lph fuel pumps?Stock?
Old Jul 25, 2006 | 04:52 PM
divette's Avatar
divette
Default mail
Я из Астрахани.
my mail - callie_reewss@mail.ru
я тебе в почту накатал
To fuel pump question
