delay in ignition when starting
Old Jul 26, 2006 | 10:35 PM
see4vette's Avatar
see4vette
Default delay in ignition when starting
Hello-
have 1992 convert.
here is the problem-
when I put the key in the ignition and turn to start, seems like ther is a delay before you here the starter and it fires up. has never done this.takes 1-2 seconds before you here anything.
only things done different-
1)washed engine real good, but that was a week ago.
2) went to have a ignition key made, lock shop cut a #7 code key instead of a #5 key. tried it and it shut everything down for about 5 min. my key would not even work. worked after letting it set
Thanks, see4vette
Old Jul 26, 2006 | 10:45 PM
rayosequis's Avatar
rayosequis
Your first problem is washing the engine, LT1's use an optispark which is extremely sensitive to water and it is strongly reccomended that you not wash them. Do a search on them and you will find plenty of information.
Old Jul 27, 2006 | 07:35 AM
pcolt94's Avatar
pcolt94
Even though it is good advice not to wash the engine, I don’t believe that has anything to do with your starting problem. If it was a VATS problem, it would not correct in 2 seconds. As you know the reset time is a few minutes. You could have the starter starting to go bad. But first I would remove both battery terminals and clean and tighten properly.
Some other ideas but will probably find nothing are:
Check tightness of nuts on starter
Re-seat start relay under dash
Check key switch and rod assembly (not key cylinder) in steering column.
Can’t think of anything else to streach to unless more info provided. Best of luck.
To delay in ignition when starting
