Highbeam indicator i
Old Aug 2, 2006 | 03:18 PM
sallen's Avatar
sallen
7th Gear
Default Highbeam indicator i
I have a 94 vette and my highbeam indicator often does not luminate on the instrument panel. Does the steering wheel position or dimmer switch has a bearing on this issue.
Old Aug 2, 2006 | 05:29 PM
MRBILL1957's Avatar
MRBILL1957
I have a similar problem, mine will illuminate but will stay illuminated even when i turne the brights off. what could be causing that?
Old Aug 2, 2006 | 05:37 PM
Jerris's Avatar
Jerris
I have this same problem on my 92 sometimes.
Old Aug 3, 2006 | 12:04 PM
pcolt94's Avatar
pcolt94
The CCM controls the the highbeam indicator lamp. The highbeam lamp has 12 volts on it and the CCM completes the circuit to ground when commended. The command comes from the headlight highbeam dimmer switch lever which is input to CCM.
Possibility:
1) the bulb is bad or has a bad connection in instrument cluster.
2) Wiring to the CCM or instrument cluster, as in a connector
3) defective CCM (probably not)
4) Highbeam lever defective
The diagnostics for the CCM (short 4 and 12 on ALDL) can envoke a test mode and cycle (turn on and off) the highbeam lamp. Go to modual 1.4 test 05. This will help isolate the problem area as wheather the CCM is controlling the lamp correctly.
To Highbeam indicator i
