You guys and this forum are the best! I was having trouble with the automatic climate control in my 96. I could not lower the temp or select off, auto, or bilevel. Turned out to be the plug in the back of the control unit needed a wiggle. Before I even posted my problem I did a search and found several threads on the subject.
Not really. You have to unbolt the center console and raise it up so you can remove the dash panel so you can remove the AC controller. Takes about an hour.
