LT4 spring install height ?
Old Aug 9, 2006 | 01:55 PM
opel's Avatar
opel
Default LT4 spring install height ?
The LT4 springs have a seat pressure of 101 at an install height of 1.780 what would the seat pressure be at an install height of 1.780?
Dave
Old Aug 9, 2006 | 02:00 PM
ALLT4's Avatar
ALLT4
Dave
Huh?
Old Aug 9, 2006 | 03:27 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Dave
101 lbs, What did i win
Old Aug 9, 2006 | 04:23 PM
Slalom4me's Avatar
Slalom4me
I think Opel meant to say
Now I have a question on LT4 springs @ install height of
1.780 the seat pressure is 101 pounds. What would the
seat pressure be at install height of 1.750?
In other words, what should the seat pressure be at a 0.030" lower installed height?
He recently asked at the end of his cam thread: Ok what cam do you think?
Old Aug 9, 2006 | 06:44 PM
500hp's Avatar
500hp
The LT4 spring is a relatively LIGHT duty spring. Another .030" might increase seat pressure to 110 lbs, certainly no more than 115 lbs. Even if it was 120 lbs this would be totally acceptable using the stock roller lifters with approximately 'one full turn' of preload.
Old Aug 9, 2006 | 06:52 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
If you're using a cam with near .500" lift or more, don't do it. Otherwise, it should be okay.
Old Aug 9, 2006 | 07:02 PM
500hp's Avatar
500hp
Yes, I agree. The LT4 spring is at its absolute limit at the .525" lift of the HOTcam (when installed at 1.780"). Anything over .500" lift I would recommend a better aftermarket spring.
Old Aug 9, 2006 | 11:47 PM
ALLT4's Avatar
ALLT4
Don't even **** around with the LT4 springs. At first I thought they'd be OK but after many discussions with 500hp and others on the forum they're pretty mild and BARELY up to the job with the Hot Cam.
Get these from crane , more seat pressure and rate at stock installed height (but not too much) and they fit better than the stock LT4 springs. Also you can use all your stock spring hardware.
Here's how they fit, I just got done installing them a while back. BTW, I've made a ton of 6500 shifts so far in my LT4 car with the stock spring hardware without a lick of trouble.
Old Aug 10, 2006 | 01:01 AM
opel's Avatar
opel
Ok that's what I get for posting after being up for 24+ hours. Slalom4me is correct I meant what would the pressure be at 1.750? This is not a LT4 engine or even a roller lifter engine, my cam should have springs with 114 seat pressure and the lift is 467/494 I think the LT4 springs would be a better choice than my current springs + I already have them.
Dave
Old Aug 10, 2006 | 02:12 AM
Slalom4me's Avatar
Slalom4me
Opel, I don't have any knowledge about the spring and defer to what
these guys say.
What I ask is that you consider how much money you are looking at
for a spring that is more compatible and whatever loss there might be
on selling the LT4 set versus the cost of the consequences of sticking
with the LT4's and having an issue.
How much margin will there be before coil bind occurs?
Old Aug 10, 2006 | 07:10 AM
ALLT4's Avatar
ALLT4
Dave
The LT4 springs will work for you. Is that .494 spec with your rockers? You could use a bit more seat pressure but it's acceptable.
With 1.5 Rockers...
Your installed height. 1.750
Coil bound completely. -1.1875
Gross max lift. .5625
Your max lift. .494
Margin. .0685
With 1.6 Rockers...
Your lift. .527
Margin. .0355
Stick with 1.5 rockers to provide the .494 lift, at .527 lift you're getting into a danger zone.
To LT4 spring install height ?
