need some help....does your car do this too....? for automatic transmissions......
was wondering.....how everybody's first to second gear shift is like....mine is like....it revs and revs....pretty high...then....around 40 hits 2nd and really jerks you back into the seat.....I guess my question.....is like.....is the car suppose to rev a little while, then go into second.......?
I have my tv cable to shift the car at exactly 13......... this is of course just having the car basically at an idle.....and barely with the gas.
thanks guys......
Re: need some help....does your car do this too....? for automatic transmissions...... (XtremeVette)
Not sure I fully understand, but if you are getting a "slip bump" when it shifts, then the TV cable could be out of adjustment. Don't use the TV cable to try to alter the shift points, you are asking for trouble.
Re: need some help....does your car do this too....? for automatic transmissions...... (vettenuts)
Bob....I have re-adusted my cable......due majorly to get rid of a sluggish feeling and a very low delay in upshifts....I was getting a torque converter chatter feeling before...since me adjusting the cable and pulling it backward toward the firewall, I have gotten rid of the sluggish feeling and chattering.....the car now downshifts very quickly when slightly depressing the accelerator. So I guess my question would be...I need to find a balance and where the tv cable should be set at.........right now it is a little more than just inside......(in otherwords the plastic plunger's end (flat spot) that is on the cable is just inside of the reset box...... if you have a picture of where yours is I would appreciate it....this way I can see from reference how close Iam........
like I said...I get more performance now...and the shifts have been delayed a bit....but I almost think this is the way the thing should run.........since Iam the 3rd owner of the car.......and have not really driven another vette...I don't really know.....thanks again....is it correct in assuming that more tv line pressure is better than less tv line pressure....i have heard if there is not enough....you start burning clutches....but I have not heard any downsides to too much pressure....?....
basically i don't want to hurt my tranny....is the bottom line...but I dont' want to get the chatters back either.......
You can increase the line pressure up to a point to increase shift firmness and to obtain slightly higher shift points at wide open throttle. Further increases to the pressure results in the transmission “holding” the gear too long during part throttle (normal) driving. If you are not shifting out of first gear until 40 mph and you are at part throttle, you need to reduce the line pressure.
