It should fit, the tunnel on my 1986 is 10" wide but the seat belt studs reduce the width to 8.5" near the back of the tunnel. The 4.5" in height will be tight but if you position it up as far as you can it should not hit the ground.
420 Cube
11.28:1 compression
AFR 210 cc heads
Ported Miniram II
TPIS 700-702 cam:
248 intake 248 exhaust @ .050
.649 intake lift
.651 exhaust lift both with 1.6 roller rockers
The lift figures take into account the really tight .010 lash on the solid roller cam.
110 lobe separation
TPIS headers, dual 3" mandrel bent exhaust, custom xpipe and Borla XR-1 race mufflers.
There isn't any tuning done on this motor yet. The Accel gen 7 is still sitting in my garage.
Goldvette, that sounds pretty sweet man! How is it to cruise around in traffic if you dont mind my asking? I'd like to know a little bit about your tranny and gearing. Like Ron said, I've got a 421 also but mine is built way-way on the tame side compared to yours
Like you, I was thinking my exhaust was choking the motor down also (I've got Hookers into a 3" RT cat, then 2 1/2 out thru my Flowmasters) but when i dyno'd it thru just the headers alone it only gained like 15 or 20 HP............I was shocked! It even got a little more torque too
Other than the idle, needing a little work in the first clip it sounds great. It would probably get a little loud for me in normal cruising....guess I'm getting old, but I can tell the motor sounds healthy !
