Fram Oil Filter Experience
Old Aug 19, 2006 | 01:43 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Originally Posted by Perfusion
Mobil-1, AC Delco, Wix, and/or K&N - that's all you need.
Old Aug 19, 2006 | 02:38 AM
comp's Avatar
comp
NAPA is WIX
Old Aug 19, 2006 | 05:15 AM
Scooter 94's Avatar
Scooter 94
Originally Posted by flatbush862
Been seeing bad press on them and they probably are not what they used to be but I have been using them for 15 + years on various vehicles for well overr 100K miles -no problems.
Same here, been using them on most of my vehix since early 1980's with no probs. Always use PF52 on da vette though, just because.
Old Aug 19, 2006 | 09:12 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
PF52 is AC Delco, Fram is 3980
Old Aug 19, 2006 | 09:47 AM
Red Tornado's Avatar
Red Tornado
I use Purolator "Pur One" or Napa Gold.
The Fram thing scares me.
Old Aug 19, 2006 | 10:09 AM
Rich & Lisa_84's Avatar
Rich & Lisa_84
From: I live at www.domesticlugnuts.com I sleep in PA
I was using Fram filters up to about 2.5 years ago.
I noticed after changing the oil, that my pressure was down by 20 psi.
I drove it for about a week and it stayed 20 psi lower than normal.
I changed the filter again and it was still down by 20 psi.
So I installed a Purolator and the oil pressure went back to normal.
Now, the only 2 types that I will use are Purolator and AC Delco.
Old Aug 19, 2006 | 10:21 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
I always used Fram until I had one of their fuel filters come apart inside and stop the flow of gas. Then I read all the horror stories about the oil filters and now I wouldn't use one as a paperweight. AC for my wife's Buick and my GMC truck and K&N or Wix for the Vette. Think about it, where do you find Fram? Wal-Mart and any other volume, buy/sell cheap outlet.
Old Aug 19, 2006 | 11:06 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Originally Posted by JrRifleCoach
ditto; K&N here
Old Aug 19, 2006 | 01:48 PM
Snakeskinner's Avatar
Snakeskinner
AC Delco 1218 works well for me parts man ,an old racer
said something about oil pressure @ start up better.
I got to believe that any OEM filter used on an engine under warranty
has a superior design for a STREET motor.
Some of the K&N filters let particles thru that OEM filters catch
maybe the do this for better flow on RACE motors that have very frequent changes.
Old Aug 19, 2006 | 02:05 PM
96lastc4's Avatar
96lastc4
We had everyone bring in old oil filters at work and we cut them all open. We found that Fram in general had the poorest construction and had less cleaning material in them. We looked at Pennzoil, Puralator, Fram (all three styles),Quaker state and Wix. Of the filters we looked at Wix was the better of the bunch. Pennzoil and Quaker state also were very bad.
Old Aug 19, 2006 | 04:39 PM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
Originally Posted by CAJUN C4
Anyone have a bad experience with using Fram Oil Filters?
No - and I seriously doubt there is (firsthand) concrete proof by CF.com members to prove otherwise
Old Aug 19, 2006 | 04:49 PM
ccford's Avatar
ccford
I use and recommend the depth type filters manufactured by Hastings and Donaldson. Depth type filters filter smaller particles and hold more material prior to bypassing. These are somewhat hard to find in stores. I usually order a few online.
J
Old Aug 19, 2006 | 05:24 PM
  #33
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
, my dad has always used them, and so have i. never had a problem.
Old Aug 20, 2006 | 05:18 PM
  #34
Mike_88Z51's Avatar
Mike_88Z51
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
Originally Posted by onedef92
If you have a noisy valve train at startup, this filter is likely the cause. The bypass valves are plastic and are sometimes not molded correctly, which allows them to leak. ...
I personally have experienced the noisy valve train at startup problem that onedef92 mentions. I used a Fram oil filter on my Nissan 720 Pickup for years. As long as I could remember the Nissan had a noticeable valve noise at startup every morning before work. I read the Oil Filter Study http://minimopar.knizefamily.net/oilfilterstudy.html by Russ W. Knize, and decided to switch away from the Fram filters. Immediately after switching to Purolator, the noisy valve train at startup sounds ceased. At the next oil change, as a check on my observations I used a Fram filter again, and the valve noise at startup came right back. I changed the filter out to a Purolator the following weekend and again the noise disappeared. I have never again used a Fram filter. I threw away the extras I had on my shelf for my Vette and Caravan.
Use the above link to review the oil Filter Study and you will know why "Pennzoil and Quaker state also were very bad."They are made by Fram.
Old Aug 20, 2006 | 06:16 PM
  #35
danziger's Avatar
danziger
I like Purolator and, don't shoot me, Super-Tech (Wal-Mart brand). There are only a few actual differnet oil filter manufacturers, but like batteries, there are many different brands.
Old Aug 20, 2006 | 09:26 PM
  #36
xflagz51's Avatar
xflagz51
Originally Posted by comp
NAPA is WIX
CARQUEST is also WIX. For what it's worth, I was on a Bush North team for a little while in '97 and the only oil filters you saw around the garages were WIX and I've been using the above filters or AC. I didn't realize that Fram was getting bad press, haven't heard about any issues personally, but that doesn't mean there aren't any. If you guys want to see some really scary stuff appear in your oil filters, install a Mag Filter, they will catch any ferrous metal circulating around with the oil. This almost sounds like the "best oil" or "best spark plug" threads, a very subjective subject.
Old Aug 20, 2006 | 11:56 PM
  #37
CMYC4GO's Avatar
CMYC4GO
NAPA is WIX
As well as AC, and I believe K&N. Wix is the largest filter producer in the world, and makes several leading, and house brands.
To Fram Oil Filter Experience
Old Aug 21, 2006 | 07:38 AM
  #38
Aquaman92's Avatar
Aquaman92
Originally Posted by -=Iron Mike=-
I've run Fram for years on all of my vehicles. Not a single problem.
Old Aug 21, 2006 | 11:03 AM
  #39
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
AlliedSignal was an aerospace, automotive and engineering company that acquired and merged with Honeywell for $15Bn in 1999, after which the new group adopted the Honeywell name.
AlliedSignal was created through a 1985 merger of Allied Chemical & Dye Corportation and Signal Oil, the company renamed to AlliedSignal on September 19, 1985.
The company's involvement in aerospace stems from a previous merger between Signal Oil and the Garrett Corporation in 1968. After that merger, aviation became the company's largest division.
In 1999, AlliedSignal acquired Honeywell and took its more-recognizable name. The acquisition was meant as a final triumphant move to cap off a long career by AlliedSignal's CEO, Larry Bossidy.
As of 2006, its automotive products include Fram Filters, Autolite Spark Plugs and Prestone Anti-Freeze.
Both Fram and Autolite were AlliedSignal brands since 1973, purchased from other companies by Garrett's Bendix division. The Prestone brand was acquired in the late 1990s.
Back in the day (the 1970's) Fram oil filters were among the best you could buy.
However, their current quality control measures are seriously lacking, IMO, and I only hope it doesn't spill over into their other automotive products.
Old Aug 21, 2006 | 12:44 PM
  #40
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
St. Jude Donor '12
No bad experiences, but I just changed from putting them in the DD.
Now, I don't know what they cost where you are but the Fram oil filter for my 01 Rustang is just shy of $3 at the local WallyWorld. The NAPA select filter is $3.69. So for 70 cents I have the peace of mind that my oil filter won't be a problem. Worth the $0.70 to me.
