I personally have experienced the noisy valve train at startup problem that onedef92 mentions. I used a Fram oil filter on my Nissan 720 Pickup for years. As long as I could remember the Nissan had a noticeable valve noise at startup every morning before work. I read the Oil Filter Study http://minimopar.knizefamily.net/oilfilterstudy.html by Russ W. Knize, and decided to switch away from the Fram filters. Immediately after switching to Purolator, the noisy valve train at startup sounds ceased. At the next oil change, as a check on my observations I used a Fram filter again, and the valve noise at startup came right back. I changed the filter out to a Purolator the following weekend and again the noise disappeared. I have never again used a Fram filter. I threw away the extras I had on my shelf for my Vette and Caravan.
Use the above link to review the oil Filter Study and you will know why "Pennzoil and Quaker state also were very bad."They are made by Fram.
I have. My wife's 1990 MPV used to experience valve lash adjuster ticking at cold-start whenever I used Fram filters.
I even went to the trouble of replacing all the valve lashes with new ones and the problem kept happening. Once I got hip to the Fram oil filter scuttlebutt, I went to Bosch, NAPA and other reputable brands and the problem never occurred again.
I don't trust Fram oil filters and I'm soured against their AirHog air filters, too.
i only use AC Delco have had bad things happen when i used fram i usted to work in a shop and you would not believe the
sh*t those filters would to to motors when i would get under a car or truck with a fram the frist thing i would do was change the oil and filter and tell the customer naver naver use that filter again most of the time the oil psi would go up atleast 5 to 10 psi then i would work on the car
I like Purolator and, don't shoot me, Super-Tech (Wal-Mart brand). There are only a few actual differnet oil filter manufacturers, but like batteries, there are many different brands.
I may have missed it but for what its worth the SuperTech filters are actually made by Champion Labs. They make their own marketed under the "Champ" label. Beyond that they make filters for others including K&N, Mobil 1,STP.
As I was working in a full-service gas station back in the early 70's Fram was "THE" filter. If Fram made one that fit your vehicle that was what we used back then. Their quality was well known throughout the industry. Fast forward thirty plus years and they seem to be known for the exact opposite and at the same time a filter from WallyWorld (SuperTech) has gotten rave reviews within both the auto and motorcycle communities.
Ahh...the simple times of the high school years....
Fram and Lee's Two-Stage Maxi Filter used to be the shet back in the day. But Fram's ghetto garbage, now.
The fact no import or domestic auto manufacturer uses them as O.E.M. equipment should speak volumes about their quality (or serious lack thereof).
When I was growing up in the sixties and seventies(yes,Creoleman's gettin' old), Fram was THE brand to get for your oil filter needs. Now(?) Say it ain't so! How does a quality brand turn to disreputable garbage?
I was buying the Super-tech before they were called Sper-tech to support my 5 vehicles including the vette. They started making them smaller with the same number hence less filtering area. So I switched Fram thinking I was getting a much better filter for not much more money. Sounds like I might need a change again.
