MAF Relay Question?
Old Aug 19, 2006 | 11:45 AM
CG77VETTE's Avatar
CG77VETTE
Default MAF Relay Question?
Are the two relays behind the battery on an '86 L98 iron head base coupe the same exact part? They look identical to me. I thought there were two burnoff relays and one power relay. If there are supposed to be three, then where is the third one located? Thanks for any help.
Old Aug 19, 2006 | 12:08 PM
vader86's Avatar
vader86
just 2, and they are listed as the same
Old Aug 19, 2006 | 12:17 PM
RRT vette's Avatar
RRT vette
same thing and just the two.
Old Aug 19, 2006 | 12:42 PM
CG77VETTE's Avatar
CG77VETTE
Thanks for the help guys
Old Aug 19, 2006 | 12:43 PM
Repzard's Avatar
Repzard
I just replaced my relays on my 86 and they are differant part numbers
but look the same
If they act the same im not sure
Old Aug 19, 2006 | 01:00 PM
Repzard's Avatar
Repzard
Heres the other post with update
Thank again all
http://forums.corvetteforum.com/show....php?t=1474686
Old Aug 19, 2006 | 01:55 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Third one could be an aux cooling fan relay.
The burnoff and maf relay have different p/n's I think, but any GM 5-pin fan relay will work there.
Old Aug 19, 2006 | 04:13 PM
CG77VETTE's Avatar
CG77VETTE
I replaced both with two same part number units and all is well. Once again, thanks for all the input and have a great weekend!
To MAF Relay Question?
