How do I tell if I get False-Knock?
Hi all, back from not posting in a while. My question is this :
I have replaced my Knock sensor in my '85 vette a few months back, and I could swear my performance has been dropping. the car feels fine when I punch it at low rpm's, but once I hit around 3500+ rpms, she sounds liek the timeing gets way retarted. Deep and louder exhaust tone too. The initial timeing of 6Degrees advanced has not changed since I got the custom chip in the car years ago, so thats the same. My Fuel pressure lives at 43psi, and bumps to 54 when I go WOT, so that checks out. I have a brand new High-Flow CAT installed 4 months ago, so thats not clogged. Before the knock sensor was replaced she pulled VERY strong till about 4800rpms. My valves do make some clicking noises I have noticed.
Thanks for any info guys (and gals).
MrNuke :crazy:
MrNuke :crazy:
Re: How do I tell if I get False-Knock? (MrNuke)
You need a scanner hooked up to see if you are getting timing retard.
If the computer is pulling timing, you will go slower.
Vic
Vic
Re: How do I tell if I get False-Knock? (Vic'89)
Hmm true..
So other than spending hundreds or thousands of dollars on a diagnostics computer how can I check that out?
:crazy:
:crazy:
Cruise-In II Veteran
Re: How do I tell if I get False-Knock? (Sarkee)
Check out the ECS upgrade on my site. It eliminated my knock problem and it still detects true knocks (I advanced base timing to beyond +12 deg just to test it out). After this ECS upgrade, I just a HyperTech Stage II chip and with +6 deg base timing I get one knock count at 5,400rpm on a WOT run. So I think she is just about right.
BTW, you can get free scanner software or buy an AutoXray for about $200 or so to scan your ECM via the OBD-I connection. When you compare shop flat rates for diagnostics vs cost of a scan tool and several good books, you find that the tool quickly pays off.
Re: How do I tell if I get False-Knock? (65Z01)
Thanks for all the help guys.
One part than I am NOT at all familiar with is my car's computer /ECS (although thats funny as Im a computer system engineer).
Anyways, Ill probably get an AutoXray soon to check it all out.
:seeya
:seeya
Re: How do I tell if I get False-Knock? (JAKE)
Your 'custom' chip probably has too much timing - a common problem for 'custom' chips. Make a real chip.
Check your plugs for signs of detonation.
Jake, I think it was about $70-$80 retail but my GM parts guy gave it to me a jobber's rates or ~$52.
I then went to O'Reilly's Auto Parts and they checked and have a Borg/Warner - # ESC109 - for $55.60, but it's not available nation-wide and is factory back order.
Bad news both ways.
Jake
[Modified by JAKE, 4:34 PM 9/11/2001]
