Testing Opti For High Res Pulse 1992?
Changing the RPM changes the frequency.I would not tell anyone to do this that did not have the technical ability, proper tools and documentation. Good electronics knowledge and practices should apply here. You can imagine what damage can be done. The high resolution is just a square wave of equal pulses and the low resolution is square waves of varying widths as relating to the different cut outs in the disk. Its pretty neat though to look at. You can also scope the ignition control drive, pin B (white wire) of the ICM (output of the PCM) . Best of luck, have fun.
1) The harness to the opti has been compromised.
2) The opti is dead, long live the opti.
That's it. Nothing else can cause that code.
I'd add that there are two other possible causes, though they are far more obscure & unlikely:
1. A dead input on the high-res signal line in the ECM.
2. Tom Piper has posted here that he's seen a case or two where the coil wire was running very close to the Opti harness, and either arcing over to, or inducing enough hash into, the Opti harness to trigger bogus Opti codes (he also noted that the '92 C4 had a shield on the Opti harness that should prevent this -- this shield was eliminated beginning in '93).
Be well,
SJW
Be well,
SJW
As for #2, I vaguely remember those comments Tom P. made.
